Question COM_KUNENA_WARNING_MENU and all other _MENUS appeared
I was seeing the " Strict standards: Only variables should be assigned by referenc "
/home/gameworl/public_html//plugins/system/kunenasocialshare/kunenasocialshare.php on line 29
And all the menus have stuff like this:
COM_KUNENA_WARNING_MENU etc.
I disabled the kunena Social share plugin so the error at the top of the screen doesn't appear.
But instead Iam getting all buttons replaced by "COM_KUNENA_" messages! What is going on? Please check www.gameworld.gr/forum and help.
Thank you.
One final thing. I have a final error message:
Please check your Joomla menus: COM_KUNENA_WARNING_MENU_NOT_KUNENA
I just installed language packs if you remember.
Maybe this line is not translated in your language, but it has nothing do to with broken menu items.I just installed language packs if you remember.
Maybe it helps if you click the Rebuild button. Example: Menus -> Main Menu -> mark menu items -> Rebuild ( but create a database backup previously).How can I check my menus? Please give me details.
So tell me how can I translate this greek file. What file should I edit (exact path) and in which line?
Also I can help you with greek translation as I have worked in 3 joomla components in the past. JReviews, JomSocial and JFB Connect.
I've checked it, this line is correctly translated. But is has nothing do to, that the message is displayed.Maybe this line is not translated in your language
Exactly should that be displayed "Το προκαθορισμένο στοιχείο μενού στην Σελίδα Εισόδου δεν δείχνει στο Kunena."
So check the menu Kunena item "Home Page" ( see also here ).
If you want help, please create a account on Transifex , then click on Request for Greek language.Also I can help you with greek translation as I have worked in 3 joomla components in the past. JReviews, JomSocial and JFB Connect.
