Question Menus - I must be missing something
9 years 3 months ago #194471 by lappleget
It does it in protostar also.
So to get the tabs I wanted I added to the kuena menu a number of show categories - that is how I have the tabs now
Prior to adding these tabs I did a check and the breadcrumb menu worked fine.
So am I doing it wrong. I added these under the forum (home) with the index of the menu that was created by kunena.
so it seems to be taking the path of how those go
home > board
then when you look at a topic it goes to
home > board > section title > board > topic
I hope that helps
I have a test site set up and can get you a login to it so you can see if you want.
9 years 3 months ago #194472 by rich
Ok, please give me access. you can use the confitential tags (close symbol), then only you and we moderators can see it. Or send a mail to rich@*kunena.org (address without star).
9 years 3 months ago #194473 by lappleget
I just emailed you the information with links to the test site.
9 years 3 months ago - 9 years 3 months ago #194478 by rich
I had problems with the frontend login. You had created my user account with Joomla access, therefore I was not in the CB user list.
Your startpage was the Index? I'm not sure anymore, but you can change it, when it's not right. Change the start page in the Kunena Menu -> menu item Forum (Boards). docs.kunena.org/en/faq/kunena-menu
Your problem is, that you use the same category names as the menu items.
Example:
You are here: Home -> Boards -> Discussion-> Boards -> Discussion -> Name of topic
Green are the names of menu items
Red are the names of your categories
In principle are the breadcrumbs correct, but it's not optimal if you use the same names for menu items and categories. And also the alias names are the same. That can cause some conflicts, which then eventually occur.
Last edit: 9 years 3 months ago by rich.
