Question How to increase fonts size in Kunena v5 [SOLVED]
8 years 9 months ago #193693 by rich
I've the "important" not forgotten, but I don't know whether your template has a own custom.less . If not, you can add this codes also at the end of your Joomla template.css (or when exists custom.css).
8 years 9 months ago #193695 by Kotsolis
Tell me what is the location of that .css file in the default Kunena template.
I want the full path directory of that file. Of custom.css . If you tell me the path in the default template then I will find it in the template that I use.
8 years 9 months ago #193700 by rich
Path is for Crypsis "components/com_kunena/template/crypsis/assets/css/custom.css"
or in your Joomla template "templates/template name/css/custom.css"
8 years 9 months ago - 8 years 9 months ago #193725 by Kotsolis
There is no custom.css file there.
Also, in my template, the custom.css file is 0 bytes.
Any suggestions on which file to edit? Look at the screenshot.
Last edit: 8 years 9 months ago by Kotsolis.
8 years 9 months ago #194108 by rich
Official Kunena templates create this file automatically ( see here ), when you edit these in the backend. but you use another template.
Yes, if you have no entered any codes then is the file empty.
You should not edit any files. Add the codes which you want edit in the custom.css or at the end in your Joomla template.css. You find the codes with browser tools such as Firebug (if you press F12).
8 years 9 months ago - 8 years 9 months ago #194112 by Kotsolis
Ok so I will put these codes you said in which file exactly?
Α)In the components/kunena/custom.css ?
Β)in the templates/default/template.css ?
οr C)Ηere with this method? - docs.kunena.org/en/manual/backend/templates/edit-less , by editing custom.less ?
.layout#kunena .topictitle {
font-size: 130%;
.layout#kunena h1, .layout#kunena h3 {
font-size: 2.0em;
.layout#kunena #kbbcode-message {
resize: vertical;
font-size: 1.1em;
.header-desc {
font-size: 1.1em;
Time to create page: 0.237 seconds
