Question How to increase fonts size in Kunena v5 [SOLVED]
8 years 9 months ago #194113 by rich
Ξ—ere with this method? - docs.kunena.org/en/manual/backend/templates/edit-less , by editing custom.less ?
Yes, optimal is the custom.less. If you have a custom.less then use for changes in your Kunena template only this file.
But it works also if you add the codes at the end of your Joomla template.css.
8 years 9 months ago - 8 years 9 months ago #194118 by Kotsolis
I have edited the less file. I prefer that than to risk editing template.css
I've put this code, I saved, I cleared cache, and I see no changes.
Look in www.gameworld.gr/forum
Can you help? Also, I tried both Edit .css and edit .less and can't find the difference between them!
Last edit: 8 years 9 months ago by Kotsolis.
8 years 9 months ago - 8 years 9 months ago #194126 by rich
Your template creates the custom.files in another folder. It's not the path as it show on your added image. You should report this your template author.
The correct path is "/components/com_kunena/template/jf_simone/jf/assets/"
The custom file in this folder is empty, therefore it cannot work.
Last edit: 8 years 9 months ago by rich.
8 years 8 months ago #194814 by Kotsolis
I have put the above code here:
"/components/com_kunena/template/jf_simone/jf/assets/jf_custom.css"
The file was empty, now it has your code. Still it doesn't work even if I cleared cache and cookies.
8 years 8 months ago #195043 by Kotsolis
One week has passed!
Please respond!
8 years 8 months ago - 8 years 8 months ago #195054 by rich
You mean there is no difference? As you can see, is the current font size (on image left) bigger than on the right side (without codes). If you want more then change the size specification.
Last edit: 8 years 8 months ago by rich.
Time to create page: 0.322 seconds
