Question Search not searching the forum (indexing hangs)
9 years 3 months ago - 9 years 3 months ago #186652 by NewbieNr1
The search menu item in the nav bar in kunena doesn't search through my topics. Instead it just searches through my own joomla articles. How can I enable the search function for searching within kunena forum?
The indexing hangs and don't finish. See screenshot.
Last edit: 9 years 3 months ago by NewbieNr1.
9 years 3 months ago #186656 by rich
Replied by rich on topic Search not searching the forum
Which menu item? You mean the Joomla Search module?
9 years 3 months ago #186673 by NewbieNr1
I mean both the joomla smart search module and the kunena search menu item.
I have enabled the KUnena smart search plugin. I have indexed within smart search component but that doesn't work. Therefore I have try to index according to this guide:
docs.joomla.org/Setting_up_automatic_Smart_Search_indexing
forum.joomla.org/viewtopic.php?f=706&t=803468
But when I do this kind of index it doesn't pick up all the blog articles and forum topics, just a few.
Any ideas?
9 years 3 months ago #186674 by NewbieNr1
It seems it is the kunena smart search finder plugin that is causing the problem. If I disable this plugin the indexer works fine. But with this enabled it can't finish the indexing. Any ideas?
9 years 3 months ago #186676 by rich
Which version of Kunena is installed? There were problems with the plugin but this is already fixed.
9 years 3 months ago - 9 years 3 months ago #186678 by NewbieNr1
5.0.9 Kunena version.
Shall there be an Forum folder in the site root after one have installed Kunena? I did have one but I think it had been created earlier so I deleted this empty folder.
I have had contact with siteground's technical support and they can't find the issue on their side. They say they can't find any errors in the log files. But when I look at the indexer log file it says:
#Fields: datetime priority clientip category message 2017-06-17T05:59:47+00:00 INFO [my ip adress removed] - Starting the indexer 2017-06-17T05:59:47+00:00 INFO [my ip adress removed] - Starting the indexer batch process 2017-06-17T05:59:48+00:00 WARNING [my ip adress removed] deprecated JFile::read is deprecated. Use native file_get_contents() syntax. 2017-06-17T05:59:48+00:00 INFO [my ip adress removed] - Batch completed, peak memory usage: 19,660,800 bytes 2017-06-17T06:06:10+00:00 INFO [my ip adress removed] - Starting the indexer 2017-06-17T06:06:10+00:00 INFO [my ip adress removed] - FinderIndexerAdapter::getContentCount 2017-06-17T06:06:10+00:00 WARNING [my ip adress removed] deprecated JDatabase::getErrorNum() is deprecated, use exception handling instead. 2017-06-17T06:06:11+00:00 INFO [my ip adress removed] - Starting the indexer batch process 2017-06-17T06:06:11+00:00 INFO [my ip adress removed] - FinderIndexerAdapter::onBuildIndex 2017-06-17T06:06:11+00:00 INFO [my ip adress removed] - FinderIndexerAdapter::getItems(0, 50) 2017-06-17T06:06:11+00:00 WARNING [my ip adress removed] deprecated JDatabase::getErrorNum() is deprecated, use exception handling instead. 2017-06-17T06:06:11+00:00 WARNING [my ip adress removed] deprecated JDatabase::getErrorNum() is deprecated, use exception handling instead. 2017-06-17T06:06:11+00:00 WARNING [my ip adress removed] deprecated JDatabase::getErrorNum() is deprecated, use exception handling instead. 2017-06-17T06:06:11+00:00 WARNING [my ip adress removed] deprecated JDatabase::getErrorNum() is deprecated, use exception handling instead. 2017-06-17T06:06:11+00:00 INFO [my ip adress removed] - Batch completed, peak memory usage: 6,291,456 bytes
Any ideas?
Time to create page: 0.286 seconds
