This category is only for reporting defects or problems with Kunena 2.0 test versions. This is NOT a support forum - there is no support for test versions. Users should NOT install K 2.0 alpha or beta test versions on websites with live production data.
Wherever possible, please include your K 2.0 configuration report.
Solved K2.0.0 RC2 - menu issues with upgrade
14 years 5 months ago #126264 by roland76
sorry guys... About no topic in Recent Topics:
It was my fault. I wasn't aware that in the menue self it was also an option which categories were shown... And here are the settings different (don't show any category) instead of Kunena configuration...
I would eliminate this option in the kunena settings, because you have to set it also in the menue item.
Greetings, Roland
14 years 5 months ago #126266 by sozzled
matias: Yes, I understand what you are saying and I think the topic subject did not properly reflect the true nature of the problem. I've changed the topic subject to make it more clear what we are talking about.
roland76: Although you have resolved your problem, would you like to explain exactly what caused the problem in the first place and what steps you took to fix things up. It would be helpful to have this information available so that the next time someone has the problem that you had, we can point them to the solution that you used.
Thank you both.
14 years 5 months ago #126267 by roland76
1. Untranslated strings in Joomla menue manager weren't shown in English (everything else - Kunena frontend and backend seems working - If no German possible then English) => already so.
2. There are a setting in Kunena configuration => Fronend => "Category Filter in Recent Topics" and "Category List in Recent Topics" => they seems not working or be overwritten by the same settings in the joomla menue manager.
3. If you place a menue in Joomla menue manager with recent topics, there are settings to select categories in a second tab... And if you made a new menue point, the settings are to show none categorie. I think it would be better to show all categories for default.
14 years 5 months ago #126311 by Matias
3. This was a small bug in Joomla! 2.5 only. It's now fixed.
The following user(s) said Thank You: roland76
14 years 5 months ago #126669 by nopalot
Hello, first thanks for the great component and the great support!
I'm having an issue with the Kunena tabs on top of the forum:
Matias wrote: Kunena 2.0 has a small change on displaying menu -- you always need to have menu items UNDER your Forum menu to display the menu. Or you can use menu item alias to point to the automatically created menu. So the issue is in your Kunena menu item inside your main menu.
The (rockettheme) templates I've used so far with Joomla 2.5 do not highlight (i.e. mark the menu items as selected) menu items of type "menu item alias".
So I can either have Kunena tabs (if using a menu item alias) or a highlighted main menu entry (if the menu item not an alias), but not both...
Do you have any ideas how to get both - the highlighted main menu item and the Kunena tabs?
Thank you,
Nop.
14 years 5 months ago - 14 years 5 months ago #126675 by sozzled
nopalot: I am trying to understand how your questions relate to what we've discussed earlier in this topic and, in particular, whether your problem will simply disappear when K 2.0.0 stable is released. I am trying to understand whether the problem lies with the Rockettheme template that you are using or whether the problem is caused by the way that K 2.0.0 RC2 did not properly create menu items - something that has been fixed.
It would assist everyone, when people report various issues in testing K 2.0, if people read the "rules" posted at the top of this page. In other words, when you make a report about problems that you have found with test versions of K 2.0, please include your configuration report so that we can see if the problem is something faulty with Kunena or if the problem was caused by something you may have done.
In your case I cannot decide what is the cause of your problem but, because we don't see the problem here at this website, perhaps your problem has more to do with how you implemented Kunena and less about some software defect. I don't know. :S
Last edit: 14 years 5 months ago by sozzled.
The following user(s) said Thank You: nopalot
