Topics moved into this category relate to superseded test versions of K 2.0. Topics in this category are locked.
Important K 2.0.0 RC1 Installation Errors
14 years 5 months ago #125534 by daveyboye
Yeah, I've been having difficulty uninstalling components/modules/plugins from joomla 2.5x. Let me just say the uninstaller on joomla 2.5x is not impressive at all :( I will try the above, but not probably until this weekend as I have a very busy work week this week. Hopefully we can find the problem. Should I do a copy of the kunena database tables and then just do a new install of joomla 2.5.4 and go through the above steps and sql the kunena tables in after a kunena 1.7.2 fresh install?
14 years 5 months ago #125625 by Matias
I'd first try if my advice fixes the issue. Because of there's really no change between K1.7 and K2.0 installer at that point.
14 years 5 months ago #125809 by daveyboye
Alright, I was able to uninstall 1.7.2 and do a install of 2.0rc1. The Install went ahead and did not stop with errors. However, this is when i lay down the bad news. I now get this error when trying to access the component:
Fatal Error was detected!
Fatal Error: Call to a member function xpath() on a non-object in components/com_kunena/libraries/template/template.php on line 89
The error was detected in the Kunena Component.
For support click here: Kunena Support
or you can see this image:
i.imgur.com/8k7hN.png
14 years 5 months ago #125814 by daveyboye
I searched and found this post: www.kunena.org/forum/K20-Test-Reports/12...n-error-has-occurred
However, I went and deleted all kunena menu alias and then re-installed..still same problem. I notice the bug may have been addressed in the repository. Will there be a fix shortly?
