Solved Changing mouse hover colours in K 2.0 Blue Eagle template
13 years 7 months ago #142461 by applehc
I need the same as before, with the topics.
13 years 7 months ago #142462 by sozzled
For the "Mark all topics read" and the "Login" buttons background colour:
Add the following three lines to the end of your Joomla site template CSS file:
#Kunena input.kbutton:hover { background: #cecece !important; }
It is really difficult to change the hover colour with a selected list by using CSS. The only way I know how to do this is to change the colour, dynamically, via Javascript. This kind of change might take me several hours to work out a solution for you. Perhaps another member of the community can offer their ideas.
With the exception of this one remaining issue, have we now answered everything that you wanted to know?
13 years 7 months ago - 13 years 7 months ago #142463 by sozzled
We could change each <A> hover tag individually, like we did before with
#Kunena div.kthead-title a:hover { color: #888888 !important; }
... or we could make it easier and change all the <A> tag hover colours in your forum.
This is what you would do to change all the hover colours (including the ones for topics): remove the lines that I just mentioned, and replace them with these:
#Kunena a:hover { color: #888888 !important; }
Last edit: 13 years 7 months ago by sozzled.
13 years 7 months ago - 13 years 7 months ago #142464 by sozzled
Have we now answered all of your questions except for one (which is not possible to do with CSS)?
13 years 7 months ago - 13 years 7 months ago #142465 by applehc
Thanks, I changed the background color successful. The font color and edges can be changed too? I had not considered, sorry. Its all, no more.
The color in selected list no problem, do not worry.
Last edit: 13 years 7 months ago by applehc.
13 years 7 months ago - 13 years 7 months ago #142466 by sozzled
applehc wrote: The font color and edges can be changed too?
Yes. The color and border-color can be changed to whatever you like. I suggest that you read How do I change the colours of my template in Kunena? ;)
