Solved Last posts not showing in index view
14 years 4 days ago #136973 by 810
ok,
- go to backend
- Kunena
- Tools
- Recount Statistics
- Select all option then click on Recount Statistics on the top right
- then Synchronize Users
- select all options then click on sync
14 years 4 days ago #136975 by chessfarrell
Sorry, I don't know why I didn't think of checking the tools. :dry:
I did everything (stats and users) and it solved the main issue: all the dates are now showing how they should be showing (at least for now).
But the no topic and reply issue endures:
(1. No reply and no topic)
Kunena counts them correctly (cf. green rectangles) but doesn't display them correctly in index view (cf. red rectangles). To be fair, it's a new/different issue, so maybe I should open a new thread.
14 years 4 days ago #136976 by 810
thnx for the bug report. I added it to git. github.com/Kunena/Kunena-2.0/issues/1212
We will investigate the issue.
The following user(s) said Thank You: chessfarrell
14 years 4 days ago #136986 by thefly
ok ... I downloaded the upgrade and now, following all your instructions, seems to work correctly ... index page has the right post in a prominent place. Unfortunately we are experencing problems with the IT language pack but I think that could be just a cache issue or something related to operative system.
Thx for your help.
