Solved Last posts not showing in index view
14 years 1 month ago #135295 by chessfarrell
I've been experiencing this problem for quite some time and I'm not sure it's linked only with the latest version of Kunena. Here's an image that shows an instance of it:
As you can seen, the last (or latest) posts are not showing correctly for all the categories in index view. But it must be said that those that don't have posts which have been moderated and moved.
Any idea on what caused this problem and how to fix it? Thanks for the help and don't hesitate to reply with a link if the answer has already been posted. I did my homework but I may have missed an important post about it.
Kunena 2.0.2
Joomla 2.7.2
Site: www.amaychess.be/index.php/forum/index
htaccess: Exists | PHP environment: Max execution time: 60 seconds | Max execution memory: 512M | Max file upload: 50M
Joomla default template details : silverlab | author: LineLab.org | version: 1.1 | creationdate: 2.3.2011
Plugins: None
Modules: Kunena Latest 2.0.2
14 years 1 month ago #135300 by TKtemp
looks like that fix is already work in progress
github.com/Kunena/Kunena-2.0/issues/1091
The following user(s) said Thank You: chessfarrell
14 years 1 month ago #135301 by chessfarrell
Thanks for the info. I've just posted a reply and see where is goes.
14 years 5 days ago #136882 by thefly
Hi Guys
it's my first time I ask for support about kunena ... we are going crazy looking to find a solution with this issue.
I read your info about patch #1091 and I fixed my category.php file but the problem is still there.
If I open a sub-category and set for all the post of the page the command approve selected, the I see the index page updated with the correct sorting and the last post shown there.
Unfortunately as soon as I post a new message in any category, the sorting became crazy again showing as the last post the last but one post and it is wrong.
I attach screenshot of index and the first sub-category to let you see the problem.
Thx for any help.
14 years 4 days ago #136902 by sozzled
G'day, thefly, and welcome to Kunena
I do not know anything more about this issue than you do. What I would, however, suggest to you is that if you are adding to this topic, please read the important information that appears at the top of this page. It would assist this topic if you included your configuration report.
I sorry that, even with your configuration report, I personally don't know anything more about this particular problem but I hope someone else may be able to help you better if they have some more information from you about your website. Thank you.
14 years 4 days ago - 14 years 4 days ago #136925 by thefly
Good day to you, I'm sorry and thx for the advice ... here are the configuration set of the forum, hope this help to find a solution:
htaccess: Missing | PHP environment: Max execution time: 120 seconds | Max execution memory: 64M | Max file upload: 25M
Joomla default template details : beez_20 | author: Angie Radtke | version: 2.5.0 | creationdate: 25 November 2009
Plugins: None
Last edit: 14 years 4 days ago by thefly.
Time to create page: 0.254 seconds
