Question Enable comments for guests
14 years 3 months ago #131621 by rajeshatbuzz
Is there any ways by which we can enable comments forms for the guest users but in read only mode with some custom message such as for comments need to login/register or something
or
comments forms should have login/registration url attached with you????
cmsGalaxy
Website Developement | Design | SEO | PPC
www.cmsGalaxy.com
14 years 3 months ago #131622 by sozzled
Replied by sozzled on topic Enable comments for guests
If you want to allow guests to post in your forum, use the configuration setting:
Forum Configuration » Security » Security Settings » Registered Users Only = No
This forum configuration setting also applies to Kunena Discuss. Does that answer your question?
14 years 2 months ago #132619 by Treverer
Replied by Treverer on topic Enable comments for guests
hello,
i just made the update to version 2.0.2.
but i have still the same problem, i wrote about in the other thread.
it's the same problem/question like rajeshatbuzz describes - and, no, to change the security configuration does not help.
i will try, to describe this point again:
if somebody is logged in, he can see the comments and he can see the (quick)answer field. he also can see the answer field, if there are no comments before. everything is fine - for him.
(quote form debug modus:
[KunenaDiscuss debug: showPlugin: Let's see what we can do.. ]
[KunenaDiscuss debug: showPlugin: Displaying form ]
[KunenaDiscuss debug: showTopic: No messages to render ]
as guest, you can see the comments - but no hint (as replace for the answer field), that he must/can(!) login or register, to make a comment. if there a no comments made to the article, as guest you see nothing.
you see: we need an "Displaying form" alternative for guests.
in the last version before 2.0.x, there was a hint at the bottom of the article, that there a x comments (or the comments themselves) and that the guest must log in to write a comment. i'm not sure, but i think to remember, even the quick answer form was shown, you could write in and send - and then the guest (=not logged in as user before) was able to do the login?
okay, it's not neccessary, to build up such complicate thing. would be enough to render a hint, that you can log in at this place. that's what rajeshatbuzz want to say with "comments forms should have login/registration url attached with you???? " i think...
i hope, you can work on this point, because it is important, to show each guest, he can comment, if he want to.
i hope, you understand my bad english descripation. if not: i will try again.
14 years 2 months ago #132636 by sozzled
You need to allow guests to post in your forum as I showed you in msg #2.
I do not know about "another thread". Please post the URL of the "other thread".
14 years 2 months ago - 14 years 2 months ago #133418 by Treverer
sozzled wrote: You need to allow guests to post in your forum as I showed you in msg #2.
sorry, here is the link:
www.kunena.org/forum/K-2-0-Kunena-Discus...ifferently-to-kd-1-7
my only topic, i opened here. i wrote there about this problem before and the tread-title is clear: "TOPIC: KD 2.0 "read more" link works differently to KD 1.7"
and no: your "solution" does not solve the problem, because guest should not write in the forum.
i tried my best in bad english to describe the problem, rajeshatbuzz also did and he said clearly "Is there any ways by which we can enable comments forms for the guest users but in read only mode with some custom message such as for comments need to login/register or something"
you again give the adivice, to allow guests to write. the opposit we want. crazy... i tried your advice for two weeks, when i read your post first; noting changed in blog-view. i didn't examine the problem in that way more, because guest should not write in the forum, the only should see the posting in blog view inclusive the option to login - even if there is no posting before. (i will try again in few minutes)
but, i must say: it is okay, if this feature doesn't work anymore. but it did in further versions. seems nothing you can accept?
so, sorry for asking und sorry for trying to make kunena/joomla better :whistle:
Last edit: 14 years 2 months ago by Treverer.
14 years 2 months ago - 14 years 2 months ago #133430 by sozzled
Treverer wrote: your "solution" does not solve the problem, because guest should not write in the forum.
If guests should not write in the forum then guests cannot write comments. I do not know anything about enabling comment forms for guests but in "read-only mode". A form is a place where a user can input data. How can you have a form that you cannot input data? This does not make sense.
The topic is "enable comments for guests". I think the topic is really about "can you use Kunena Discuss to remind guests that they need to login before they can post comments?" I am not aware in some older version of the software where there was a reminder like you're suggesting. I think you're over-complicating the issue. If you do not want guests to post in your forum then you can do that. I think you can easily give people the hint that they need to register at your site if they want to make comments on your Joomla articles. I don't think that we have to do that for you.
Last edit: 14 years 2 months ago by sozzled.
