Solved My Topic is always on "0"
13 years 7 months ago #142190 by gotanyglue
Many thanks that worked great !!!
i asked in Category: K 2.0 Installation and Upgrade, before
13 years 7 months ago - 13 years 7 months ago #142192 by sozzled
gotanyglue wrote: I asked in Category: K 2.0 Installation and Upgrade, before
It helps better if you do not start new topics that deal with the same questions that you asked earlier - whether or not you get a solution. I have merged these two topics together.
I am glad that the solution that I suggested worked for you. I found the solution by searching the forum. Perhaps other people will also see this topic and will search the forum to find information if they are ever in the same situation as you were.
Last edit: 13 years 7 months ago by sozzled.
Time to create page: 0.098 seconds
