Solved Joomla/Kunena upgrade
13 years 9 months ago - 13 years 9 months ago #140581 by TKtemp
Replied by TKtemp on topic Joomla/Kunena upgrade
I would upgrade Kunena 1.6 to Kunena 2.0.4 (NOT Kunena 2.0.3) on Joomla 1.5 site (BACKUP FIRST), then install Kunena 2.0.4 on Joomla 2.5 site.
After that use PHPMyAdmin to export and import tables from J1.5 (K 2.0.4) to J2.5 (K 2.0.4)
Last edit: 13 years 9 months ago by TKtemp.
The following user(s) said Thank You: swerls
13 years 9 months ago #140724 by swerls
Replied by swerls on topic Joomla/Kunena upgrade
Okay, this is what I have done, I am SO close. I upgraded my site to 1.5.26 so I could upgrade kunena. I upgraded kunena. Then I ran jupgrade that did it's thing. I have to reinstall kunena on the jupgrade site which is fine because it keeps all of the data.
It's awesome, it keeps the same layout, and it carries over the forum posts. However, when I log in I get an error message or if I click on a post. Do you know what the issue could be? Here is the link. flexus.com/main/jupgrade/index.php/forum-105
13 years 9 months ago - 13 years 9 months ago #140726 by skybax
Replied by skybax on topic Joomla/Kunena upgrade
@swerls i just had a look at you forum and i can read all messages without any problems!
in case that you consider that the top menu disappearing is a bug it isn't! in Menu Item Manager: [mainmenu] rename the Alias for the forum link to something else ... "forum2" for example and see if this solves your problem
Last edit: 13 years 9 months ago by skybax.
13 years 9 months ago #140728 by swerls
I fixed it, it was the theme I was using. What a pain!
13 years 9 months ago - 13 years 9 months ago #140893 by swerls
Apparently it's not the theme. I tried doing all of this again so I had the latest posts in kunena from the old site and I could bum rush it today and change everything.
Here's the link, the posts throw an error. If you like on general discussion it gives you a random article. I'm so confused right now on what's happening.
Last edit: 13 years 9 months ago by swerls.
13 years 9 months ago #140895 by swerls
And I got it back again, sorry!
