Solved Error: FAILED Uncaught Exception: Duplicate entry
14 years 1 month ago #133868 by marvin
PHP Built on: Linux vps185538 2.6.18-194.17.1.el5.028stab070.7 #1 SMP Fri Oct 1 14:17:14 MSD 2010 i686
Database Version: 5.1.41-3ubuntu12.10
Database Collation: utf8_general_ci
PHP Version: 5.3.2-1ubuntu4.14
Web Server: Apache/2.2.14 (Ubuntu)
Web Server to PHP interface: apache2handler
Joomla! Version: Joomla! 1.5.26 Stable [ senu takaa ama busani ] 27-March-2012 18:00 GMT
14 years 1 month ago #134464 by StormFlash
Hi! And the answer will that be? The fact that I have a similar problem with the installation of the forum. :(
P.S. Sorry for my english
14 years 1 month ago #134471 by xillibit
Clean the table kunena_aliases and re-try the Kunena isntallation
14 years 1 month ago #134648 by StormFlash
Still does not work ...
14 years 1 month ago - 14 years 1 month ago #134655 by xillibit
In /administrator/components/com_kunena/install/data/sampledata.php remove the following lines at line 150 :
$aliasquery = "INSERT INTO `#__kunena_aliases` (`alias`, `type`, `item`, `state`) VALUES ({$db->quote($section_alias)}, 'catid', '1', 1), ({$db->quote($cat1_alias)}, 'catid', '2', 1), ({$db->quote($cat2_alias)}, 'catid', '3', 1);";
And line 205 remove :
$db->setQuery($aliasquery); $db->query(); if ($db->getErrorNum ()) throw new KunenaInstallerException ( $db->getErrorMsg (), $db->getErrorNum () );
Do it in the installation package and re-try the installation of Kunena after
Last edit: 14 years 1 month ago by xillibit.
The following user(s) said Thank You: StormFlash
14 years 1 month ago #134666 by StormFlash
Big personal thanks to you! It worked! :woohoo:
Together attachments that are already patched version of your wonderful component. You never know who else needed.
File Attachment:
File Name: com_kunena...9-02.zip
File Size:1.73 MB
