Solved Error: FAILED Uncaught Exception: Duplicate entry
14 years 3 months ago #130695 by whiteamerica
Hi guys! I downloaded your forum version 2.0.1 for my Joomla! 1.5.26, but installation failed with this error:
FAILED Uncaught Exception: Duplicate entry '-' for key 1 SQL=INSERT INTO `jos_kunena_aliases` (`alias`, `type`, `item`, `state`) VALUES ('-', 'catid', '1', 1), ('-', 'catid', '2', 1), ('-', 'catid', '3', 1);
Please help me with it.
Thx!
14 years 3 months ago #130757 by xillibit
Is it a clean install or do you have upgraded from a previous version ?
14 years 3 months ago #130773 by whiteamerica
It's a clean install.
14 years 3 months ago - 14 years 3 months ago #130788 by sozzled
This doesn't make sense in a "clean installation" scenario. If I was in this situation, I would revert to the site backup taken before I attempted to install Kunena and try again; alternatively, I would drop all database tables with "kunena" in them and then try to install Kunena again. Failing both these avenues to rectify the situation, I would then try the " When all else fails, try this " approach, to establish if my hosted environment was "up to spec." as far as running a Kunena forum was concerned.
Last edit: 14 years 3 months ago by sozzled.
14 years 1 month ago #133865 by marvin
Same issue repeated on clear installation of Kunena 2.0.2 on Joomla with default language different from English.
This occure in filling localized sample data.
In my case, this was Russian sample data.
The error occured in sampledata.php rows 147 to 149.
KunenaRoute::stringURLSafe convert localized forum tittles into '-' symbol.
14 years 1 month ago - 14 years 1 month ago #133867 by sozzled
Is this a properly hosted environment or is the site hosted locally (on to your PC, for example)? What kind of database system (including version) are you using? PHP version and Joomla version, too, please.
Last edit: 14 years 1 month ago by sozzled.
