Solved Upgrade Error Uncompressing com_kunena-media.zip
14 years 4 weeks ago #135803 by sozzled
Yes. If your problem is identical to the one mentioned in msg #1 of this topic, the solution is to read, very carefully, all of the information contained in K 2.0 Upgrade Guide . I do not know if your problem is the same as the one mentioned in msg #1 of this topic. When you wrote
bebo wrote:
I tried change permissions
What did you change the permissions to?
14 years 4 weeks ago #135823 by bebo
Thanks for reply. I was read this topic manytimes.
I change permissions just like right of file and owner. Because always, if i tried to upload kunena, owner will be root not fragtime like any other folders.
And CHMOD is 775 - TMP and MEDIA/KUNENA
I tried unzip and compressed MEDIA.zip, but it doesn't work again :/
Maybe i'm doing something wrong, but i don't know what.
13 years 9 months ago #140290 by multitwii
I have exactly the same problem and I got it whet I tried to upgrade Kunena 2.0.3 to 2.0.4
I checked permissions and tried to unpack and pack the com_kunena-media folder, but still nothing new, still having the same problem.
Bebo, did you got everything work?
13 years 8 months ago #141249 by mlotziii
I have the same problem every time I try to upgrade. I simply used an FTP client to delete the com_kunena-media file from the server and the installer advanced without any problem.
It is the only way I was able to get the install complete for the past two upgrades. I tried to chmod the folders and change the owners and groups from within SSH and nothing solved the problem. Not even changing the folders and files to '777' worked.
I figured there are no new icons or buttons that I noticed so I just deleted the com_kunena-media file and never looked back.
