Solved Upgrade Error Uncompressing com_kunena-media.zip
14 years 4 months ago - 14 years 4 months ago #126981 by jimmo
I've been trying to upgrade my forum to the latest 2.0 but I've rendered it temporarily unusable. I keep getting the following error:
Prepare Installation ... OK
Uncompressing com_kunena-admin.zip ... OK
Uncompressing com_kunena-site.zip ... OK
Uncompressing com_kunena-media.zip ... FAILED The file '/****/****/joomlapath/administrator/components/com_kunena/archive/com_kunena-media.zip' could not be uncompressed.
I was able to upgrade a different site running on the same server without any problems, I've played around with the directory permissions after referencing another thread suggesting the com_kunena and archive folder but no luck. Any help is greatly appreciated!
I was running kunena 1.7.2 and am joomla 2.5.6
thanks, 2.0 runs fantastic on my working site btw!
Last edit: 14 years 4 months ago by jimmo.
14 years 4 months ago - 14 years 4 months ago #126988 by Matias
Try to unzip and zip package again, then try if it works.
Also check directory permissions on media/kunena and tmp.
Last edit: 14 years 4 months ago by Matias.
14 years 4 months ago #126991 by jimmo
Matias wrote: Try to unzip and zip package again, then try if it works.
I have tried that with no success, thanks for the reply. I have been able to temporarily revert back to 1.7 and the install seems to go fine but i get a joomla message "unable to write entry" if that helps pinpoint anything. I've had problems with this site in particular since moving servers a while back, i don't think the permissions are quite right now but unsure where to look.
14 years 4 months ago - 14 years 4 months ago #126995 by Matias
Yeah, it's definitely file permission issue. Check above 2 folders..
The following user(s) said Thank You: jimmo
14 years 4 months ago - 14 years 4 months ago #127012 by jimmo
I changed the permissions on the media folder and also unzipped & rezipped the file com_kunena-media.zip and something made it work..lol.. thanks again!
Last edit: 14 years 4 months ago by sozzled. Reason: Change topic icon to "solved"
14 years 4 weeks ago #135788 by bebo
I've got same problem like jimo, but your solution doesn't work. I tried change permissions, unzip and compress media, but everytime same error.
Dou you have any solution?
