Solved After Upgrade Topics hang in a loop
14 years 5 months ago #126916 by coder4life
Please post your configuration report.
14 years 5 months ago #126917 by Schakkalaka
Legacy mode: Enabled | Joomla! SEF: Enabled | Joomla! SEF rewrite: Enabled | FTP layer: Enabled |
htaccess: Exists | PHP environment: Max execution time: 30 seconds | Max execution memory: 256M | Max file upload: 8M
Joomla default template details : a40_fotowissen | author: Alexander Scheubly | version: 1.0 | creationdate: 2011-04-09
Kunena version detailled: Kunena 2.0.0 | 2012-06-27 [ Diplomatia ]
| Kunena detailled configuration:
| Joomla! detailled language files installed:
Third-party components: Jomsocial 2.6.2
Plugins: Content - Kunena Discuss 1.6.0-RC2 | JomSocial - My Kunena Forum Posts 1.6.0-RC1 | JomSocial - Kunena Groups 2.0.0
Modules: Kunena Latest 1.7.0
14 years 5 months ago #126920 by 810
try also Blue Eagle 2.0 template.
14 years 5 months ago - 14 years 5 months ago #126922 by coder4life
I noticed you have Joomla 1.5 Legacy mode enabled. Kunena 2.0 is not tested with Legacy Mode enabled. It is highly recommended you move away from Joomla 1.5 Legacy Mode, as it allows some Joomla 1.0 applications to run on Joomla 1.5. Joomla 1.0 is no longer supported and maintained. Be aware if you disable the Legacy Mode plugin it might prevent one or many of your older extensions (components, modules, plugins) from working correctly.
You can disable Legacy Mode in Joomla 1.5 Plugin Manager.
Jelle is also correct, I would test that as well. There might be two versions of Blue Eagle.
Last edit: 14 years 5 months ago by coder4life.
14 years 5 months ago #126923 by Schakkalaka
this has i tried before, nothing changes
14 years 5 months ago #126925 by 810
I see that the menu is still wrong.
Please delete that main menu- Forum
also delete all items in the trash.
Then recreate menu
