Solved After Upgrade Topics hang in a loop
14 years 5 months ago #126969 by Schakkalaka
i ve disabled it because i thaught that is an error with jomsocial.
my error was that i ve not enabled it if i ve checked that this was not the error...
thanks for your grear work on kunena. it support my hobby a lot.
alex
14 years 5 months ago #126974 by Matias
What about the bug itself? Do you still get redirect loop?
The following user(s) said Thank You: Schakkalaka
14 years 5 months ago #126976 by Schakkalaka
hi,
now it works...
to many things at once changed, but i think it was the menu prob.
is there a way to mark it resolve here?
Does anyone know if tapatalk works together with 2.0?
14 years 5 months ago #126979 by Matias
As topic starter, you can change topic icon to green solved mark (not in quick reply, but in reply).
14 years 5 months ago #127203 by Charl Laas
I had the same problem.
Yo have to reassign your ACL settings for each different category and they will show again
Experience is that marvelous thing that enables you to recognize a mistake when you make it again.
Franklin P. Jones
14 years 5 months ago #127206 by Schakkalaka
no, that was not the problem of my board.
alex
