Question Attachment Detail, Userlist, Access
13 years 6 months ago #143843 by rl65
i have 3 questions.
1. When a forum user wants to attach a file to his post he cannot see the filename in the input box. Does anyone have an idea how or where to make it visible?? This is like color and background-color are set the the same color. (See attachment)
2. In the statistics area are 2 links. One is called "More statistics" and the other one is called "userlist". "More statistics" works, userlist not. Doesn't matter if you are a registered user or not. How i have to set up the paramters to allow registered user have access to the userlist?
3. I would like to have all categories visible for public. The category access should depend if you are registred or not. Can anyone explain to me how to configure that? I have tried many different settings but had no success.
Thanks very much
Rolf
The topic has been locked.
13 years 6 months ago #143863 by sozzled
Did you solve the question you asked in Profile not editable .
We are happy to answer any one question you would like to ask in any one topic but it's too confusing if topics try to address multiple subjects at the same time.
The reason why things are not working for you are probably easy to find answers for if we see your configuration report.
*** Topic closed by moderator. Reason: separate topics needed to answer all the different questions ***
