Solved How to control Kunena module display in categories?
Sorry I posted it in the wrong category earlier, I have since updated to K 2.0.
************************** Inserted by forum moderator ***************************
The original topic (for people who have no idea what we were discussing) was
How to control kunena module display in sub-forums? .
This is a continuation of the earlier discussion.
************************** End of insertion by moderator **************************
This was my original question!
I recently set up a new portal for my site, which I have managed to base the modules I want to be displayed around a "MAIN Menu". Everything works fine, except for the Kunena section and when i try to read the sub-forums or an individual thread.
*** URL removed at user's request ***
The moment I click on the categories it loses all menu structure and the modules attached. For example in that "Malaysian" link when I click on general chat it takes me to
And I lose all the modules around it. Do you have any suggestions how I can incorporate Kunena into my site across different portals?
Thanks so much.
(Im using the advanced modules mod to control mods and it works fantastically)
PS TKtemp in the other thread suggested this
If you want to do this you need to create menu structure in Joomla (Kunena) menu in the way to assign unique id for every category.
Do you mean creating a hidden menu in Joomla, then using alias to assign every individual category? Seems easy enough, as I only have a few categories. Is that what you meant? Thanks
www.kunena.org/forum/K-2-0-General-Quest...isplay-in-sub-forums
I can't edit the URLs out anymore since that thread is closed. i want to remove all the urls from my posts so my site doesn't look amateurish if i pop up in a search engine asking for questions! (I can edit the url of thie above post out later as its not closed)
Also kindly delete *this* post too after you read it! thanks
Yes, using of alias is not important, important is that you have menu item for every single category, then you can assign modules to that items.Do you mean creating a hidden menu in Joomla, then using alias to assign every individual category? Seems easy enough, as I only have a few categories. Is that what you meant?
someone please help!
How specifically are this "messed up"? I visited your site and I didn't notice any problems. Maybe I'm as blind as a bat or I was looking in the wrong places?cowcowcow wrote: ... the topics are totally ignoring the module placements on them ... *** URL removed at user's request *** is good until you click on a topic
On the other matter relating to deleting messages on the forum, we take a different opinion and we would prefer to leave those messages there because some information may be helpful to other members of the community.
sozzled wrote: From the sounds of what you've written your customised menu solution was not 100% satisfactory?
*** URL removed at user's request *** is good until you click on a topic, then the logos at the top get messed up. i wish i found that link you just gave me earlier lol.
