Question kunena_menu position not auto complete from main menu
14 years 1 month ago #134281 by woonydanny
anybody have any ideas how this can be achieved?
I want to separate the main menu items from automatically appearing also in the kunena_menu position.
still wish that i can write my forum signature through a jomsocial plugin and do it from my jomsocial profile :(
14 years 1 month ago #134282 by woonydanny
ive read here: docs.kunena.org/index.php/Module_Positions
that "The kunena_menu module position has been removed from K 2.0 templates."
why is that? i cannot publish another menu now in that location...........
13 years 11 months ago #138110 by woonydanny
still trying to work this out....
i would like 2 totally independent menus. 1 in the main menu and 1 in the kunena menu top position.
at the moment, i cannot manage to do this.
13 years 11 months ago #138113 by sozzled
I'm not sure I can help you, mate, but you might like to refresh your memory with Customised menus
13 years 11 months ago #138117 by woonydanny
My understanding is that there should just be a module position in the top of kunena where a module (in most cases a menu item) can be inserted.
what i am having problems with, is that this position is somehow connected to the main menu. i need these two independent of each other, so if i add a menu in the main menu it doesnt also show up in the kunena menu position as well.
surely others must experience this as well..?
13 years 11 months ago #138119 by TKtemp
peetree21 wrote: still trying to work this out....
Hi, the problem is that Kunena Menu by default is not joomla module published in kunena_menu position.
You should make THIS CHANGE and after that create kunena menu module and publish in this position. After that you should be able to do what you want.
The following user(s) said Thank You: woonydanny
