Solved K 2.0 Menu Class Suffix
14 years 3 months ago #131265 by Voice4Vision
Hello everyone,
I have read through the "Missing Menu" topic in hopes an answer to my problem is provided, however it is not. So I created a new topic with a more direct question in hopes for a solution.
In previous versions, I used the Menu Class Suffix of the Kunena Menu Module, to use my templates css to change my menu's appearance. With Kunena 2, this option is no longer available. So I was hoping that someone here might be able to guide me into adding my Menu Class Suffix to the current Kunena Menu!
Any and all assistance is greatly appreciated!
Thank you,
Voice4Vision
14 years 3 months ago #131312 by TKtemp
Replied by TKtemp on topic K 2.0 Menu Class Suffix
To do this you need to change one line in kunena source code (template file).
Is that ok for you?
14 years 3 months ago #131341 by Voice4Vision
Oh yea, absolutely...I am constantly changing my files. Keeping track of my edits makes upgrading so much easier! So what file do I need to edit?
Any and all assistance would be greatly appreciated!
Thank you,
Voice4Vision
14 years 3 months ago #131346 by TKtemp
Good.
Open the file: /template -> blue_eagle -> html -> common -> menu.php
Replace this code:
<?php echo $this->getMenu() ?>
with this:
<?php $this->displayModulePosition( 'kunena_menu' ) ?>
Be sure that Module Kunena Menu exist and is published in "kunena_menu" position.
Now you can use all parameters from module configurations again ;)
Regards
The following user(s) said Thank You: Voice4Vision
14 years 3 months ago #131348 by Voice4Vision
Awesome, worked like a charm, Thank you very much!!!
For anyone else that wishes to try this...you will need to select your "kunena_menu" position by manually entry(typing it out).
Thank you again TKtemp!!!
13 years 11 months ago - 13 years 11 months ago #138153 by woonydanny
Replied by woonydanny on topic K 2.0 Menu Class Suffix
TKtemp wrote: Good.
Replace this code:
with this:
Regards
thank you! thank you! thank you!
this has worked for me :) :) :)
still wish that i can write my forum signature through a jomsocial plugin and do it from my jomsocial profile :(
Last edit: 13 years 11 months ago by woonydanny.
