Question Forum statistics display problem
14 years 3 months ago - 14 years 3 months ago #131791 by sozzled
Thank you for your configuration report.
Your configuration report shows us that you are not using a Kunena template that was designed, developed, maintained or supported by the Kunena project. We do not know anything about the ja_tiris template and we cannot help you with questions that involve the ja_tiris template. This template may be the reason you are having problems with the statistics.
Your configuration report shows that you have enabled integration with the following software: JomSocial, Community Builder and AlphaUserPoints. Your configuration report does not show that you have any of this software installed. You should, one by one, examine all setting in the Kunena plugins and disable those features you do not require. These settings may be the reason you are having problems with the statistics.
Your configuration report shows us that you are using a number of outdated, unsupported Kunena add-ons that are incompatible with K 2.0.1. Please read the important notice in the K 2.0.1 release notes about trying to use outdated software with the version you have installed. Out of date or incompatible software may be the reason you are having problems with the statistics.
  • The following Kunena modules you have installed are completely unnecessary on your website and you should uninistall them: JomSocial - My Kunena Forum Menu 1.6.4, JomSocial - My Kunena Forum Posts 1.6.4, JomSocial - Kunena Groups 1.6.4.
  • If you are using the Kunena Search plugin then you should upgrade Kunena Search 1.6.4. However, because I do not see on your website where you have integrated the Kunena Search plugin with your site search facility, you should probably uninstall this plugin.
Your version of Joomla (J! 2.5.1) is incompatible with K 2.0.1; please read the K 2.0 Technical Requirements . The Kunena installation process should have stopped when you tried to install Kunena. This suggests to us that you did not perform the correct installation process for K 2.0.1 (see K 2.0 Installation Guide . You should upgrade immediately to J! 2.5.6 and re-install K 2.0.1 again. This old, outdated version of Joomla that you are using may be the reason you are having problems with the statistics.
I hope these suggestions help.
Last edit: 14 years 3 months ago by sozzled.
