Question Forum statistics display problem
14 years 3 months ago #131753 by yumsai
The top statistic should be "Most Popular Topics", but not "Most Popular Polls"
I am using the latest Kunena 2.0.1. I didnt change any code or language files.
Please HELP.
14 years 3 months ago #131761 by sozzled
The top statistics, if you use the K 2.0 Blue Eagle template, should be "Most Popular Topics". Try again using K 2.0 Blue Eagle, like we use here at this website.
14 years 3 months ago - 14 years 3 months ago #131768 by yumsai
I already change it to K 2.0 Blue Eagle
however, the problem still exist. I also find that the the backend statistic has the same problem
Last edit: 14 years 3 months ago by yumsai.
14 years 3 months ago #131769 by sozzled
We cannot diagnose the problem that you (and only you) are having only by looking at screen images.
Yes, I understand you have a problem and I don't know why you are having a problem or how long you have been having this problem for or what changes you may have made to your Kunena installation or, for that matter, what version of Kunena you are using.
It would help you to read the FAQs item on the menu above and, in particular, look at What information should I include when I ask for help (including how to post my configuration report)? .
If you do not want to give us your configuration report, that's fine. We can't help you much without it, either.
Have you tried re-installing Kunena or reset the Kunena configuration back to its original, default settings?
14 years 3 months ago #131770 by yumsai
Here is the report
htaccess: Exists | PHP environment: Max execution time: 120 seconds | Max execution memory: 200M | Max file upload: 50M
Joomla default template details : ja_tiris | author: JoomlArt.com | version: 2.5.1 | creationdate: Feb 2012
Kunena default template details : ja_tiris | author: JoomlArt | version: 2.5.0 | creationdate: February 2012
Third-party components: UddeIM 2.8
Plugins: Content - Kunena Discuss 2.0.1 | JomSocial - My Kunena Forum Menu 1.6.4 | JomSocial - My Kunena Forum Posts 1.6.4 | JomSocial - Kunena Groups 1.6.4
Modules: Kunena Latest 2.0.1 | Kunena Stats 2.0.1 | Kunena Login 2.0.1 | Kunena Search 1.6.4
14 years 3 months ago - 14 years 3 months ago #131771 by yumsai
Finally, I find out that if i turn off the "Show Popular Poll Statistics" in the backend. "Most Popular Topics" is now displayed correctly.
However, when I turn on the "Show Popular Poll Statistics" again. "Most Popular Topics" changed into "Most Popular Polls" again, very strange.
P.S I already reinstall the kunena 2.0.1
Time to create page: 0.157 seconds
