Merged What does "administrator has disabled public write access" mean?
14 years 3 months ago #131571 by sozzled
wh1te0ak wrote: So I have got all my menus now sorted ...
Not really. When I visit your site, the menu is different to what I expect to see. Your menu may work but I'm not sure it does. Did you see the video in The Kunena Menu ?
The message "administrator has disabled write access" means exactly that. You have a forum category (or categories) that you have not allowed people to create new topics or reply to topics. Check the category permissions (the permissions tab) in the Kunena Category Manager.
The Kunena template you are using is wrong for K 2.x. That template is out-of-date and, as far as I know, it has not worked properly since K 1.6.2. If you have problems with the Cridin template, please contact the person who wrote it; alternatively, use the Blue Eagle template or find another template that works with K 2.x.
I hope these suggestions help. :)
The following user(s) said Thank You: wh1te0ak
14 years 2 months ago #132290 by ChaosHead
I am sure that for SEO, repeated thousands of times, one and the same phrase - it's not very good.
Google may not be able to determine the right keywords for your website. For example you make a forum about turtles, and Google will think that your board is about administrators.
13 years 10 months ago - 13 years 10 months ago #139290 by Xuxux
Hi
I have the same issue plus some more:
1)No mater how I change the permissions, even yes to "Allow Guests to Post/Write", I can't get rid of the (Unless I turn the user, logged in, to global moderator. And when I change it back, the online user turns Offline, still logged in):
The administrator has disabled public write access.
You cannot reply to this topic.
You do not have permissions to start a new topic!
2) I am testing it as to different users, with the same result. One of them shows OnLine and another one OffLine, under the avatar, no idea why.
Joomla 2.5, Kunena 2.0.3., Blue Eagle 2.0
Any help is appreciated.
Regards Xux
Last edit: 13 years 10 months ago by Xuxux.
13 years 10 months ago - 13 years 10 months ago #139427 by sozzled
G'day, Xuxux, and welcome to Kunena.
If you post your Kunena configuration report, this community will be better placed to see why you may be having the problems that you are having.
Do you have these problems, too, in the original "Welcome Mat" category on your forum?
Last edit: 13 years 10 months ago by sozzled.
13 years 10 months ago - 13 years 10 months ago #139707 by BartG
I have the same problem.
I need forums open for Guests. Everybody can write and read.
Now everybody must register and log in.
I want to have posibility to have guests, which can write posts, and normal users with accounts. But I want to everybody can write and read all.
Config in attachment.
P.s.
Sorry but my english is as well, as should be... ;)
htaccess: Missing | PHP environment: Max execution time: 30 seconds | Max execution memory: 64M | Max file upload: 32M
Joomla default template details : gk_twn2 | author: GavickPro | version: 2.6 | creationdate: 20 Jan 2012
Plugins: None
13 years 10 months ago - 13 years 10 months ago #139713 by sozzled
G'day, BartG, and welcome to Kunena
These are your Kunena integration settings (extracted from your configuration report earlier):
Kunena - AlphaUserPoints Enabled: activity=1 avatar=1 profile=1 activity_points_limit=0
Kunena - Gravatar Enabled: login=1
Kunena - JomSocial Enabled: access=1 login=1 activity=1 login=1 profile=1 private=1 activity_points_limit=0 activity_stream_limit=0
I have highlighted in different colours the three areas that seem (to me) to conflict.
Your configuration report shows that you do not have JomSocial, Community Builder, AlphaUserPoints or uddeIM software installed on your site. See Forum integration with other Joomla extensions and reset these plugin settings back to their original, default, values. In other words, disable all these plugins except for the Kunena - Kunena and Kunena - Joomla plugins.
Time to create page: 0.157 seconds
