Question Userlist cant be sort by click on column Kunena 2.0.1
14 years 4 months ago #129252 by queenvio
Hey thanks for your answere.
One more question:
on my side it is
javascript:Joomla.tableOrdering
on yours
javascript:kunenatableOrdering
how can i change my to yours?
if i change it temp. with Firebug it works.
Greeting
14 years 4 months ago #129282 by xillibit
On your site you have J2.5 adn here it's J1.5, it's the reason why it's different
You need ot check if the name/id of form is right passed to the Joomla.tableOrdering function
The following user(s) said Thank You: queenvio
14 years 4 months ago #129330 by queenvio
sorry, i dont have many knowledge about the thema.
I just wonder that it work with J 1.5 (at your site)
and dont work with J 2.5 (the sites a few post ago)
Thanks and Greetings
14 years 3 months ago #130554 by paraflyer
Hmmmmm...same here. Sorting the columns is dead since Kunena has been updated. Checked all hints and possible errors - no change. Also Firebug seems to be OK. Trying to fix this since a week.
Any idea how to check what is wrong and why there is no sorting? :dry:
14 years 3 months ago #130561 by sozzled
G'day, paraflyer, and welcome to Kunena.
The clickable columns (column sorting) requires Javascript (especially Joomla's Mootools Javascript library) to work. Please read msg #1 in Before you post your question, read this first . The answer is there.
14 years 3 months ago #130565 by paraflyer
Thanks for your welcome! :laugh:
I already read it more than once but have no idea what it can be. Deinstalled an extension with jQuery-usage so this library is not active, checked the plugins and much more. The sourcecode looks like everything is fine.
The question is: How can I check why it's not working?! Searching for something like 'Firebug' that will tell me "library xyz is missing or damaged" or anything else. Tried it with different browsers and so on.
It's not THAT big problem, but I'd still like to sort my userlist. Is there another component that is using mootools? So I could check if this is also not working?
