Question Userlist cant be sort by click on column Kunena 2.0.1
14 years 4 months ago #129169 by queenvio
Hey guys.
I have found a problem that i see at much site with Kunena 2.0.1
You cant sort the userlist by klick on any of the column (Username, Karma,...)
I hope there will be fix soon.
Greetings
14 years 4 months ago #129190 by sozzled
The user list sort-by-column function works here, at www.kunena.org . Did you try it here?
14 years 4 months ago #129200 by queenvio
at www.kunena.org it work, but i checked it at
Nova-Ascendant (my site)
or
Ralle632
or
SPD Stade
and at none of them it work
14 years 4 months ago #129201 by sozzled
The clickable columns (column sorting) requires Javascript (especially Joomla's Mootools Javascript library) to work. Have you read msg #1 in Before you post your question, read this first
The following user(s) said Thank You: queenvio
14 years 4 months ago - 14 years 4 months ago #129235 by queenvio
So i checked the fist post and i think there is a problem with the mootool.
BUT i dont have the mootool at the system.
I upgrade joomla 1.5 to 2.5, maybe there is a problem.
hope you can give me a tip.
BTW i installed JB Library
htaccess: Missing | PHP environment: Max execution time: 30 seconds | Max execution memory: 128M | Max file upload: 3M
Joomla default template details : counterstrike_lernvid.com | author: Juergen Koller | version: 1.0 | creationdate: 22.05.2009
Third-party components: UddeIM 2.6
Plugins: None
Last edit: 14 years 4 months ago by queenvio.
14 years 4 months ago #129247 by xillibit
I encounter a javascript error :
TypeError: d.filter_order is undefined
Time to create page: 0.150 seconds
