Question Javascript pop-up error
14 years 3 months ago - 14 years 4 weeks ago #129865 by sozzled
Replied by sozzled on topic Javascript pop-up error
I don't have access to a WinXP system running an original version of IE8. Therefore, the only test I could run was on a Win7 system with IE9 simulating IE8 and, as far as that test went, I had no problems when I hovered the mouse over the Kunena menu. It is, however, clear to that you have a Javascript "software soup" whose ingredients are overpowering one another.
Let me put these issues into perspective. In msg #1 of Before you post your question, read this first we discuss various issues that cause the non-performance of Kunena on people's websites. If one studies the "form guide" over the past few years, it's a safe bet that as one introduces another Javascript library into the mix, the probability that it will not co-operate with others increases until it becomes a certainty.
Joomla needs the following Javascript libraries in order to work
<script src="/media/system/js/mootools-core.js" type="text/javascript"></script> <script src="/media/system/js/core.js" type="text/javascript"></script> <script src="/media/system/js/mootools-more.js" type="text/javascript"></script>
Kunena adds two more
<script src="/media/kunena/js/mediaboxAdv-min.js" type="text/javascript"></script> <script src="/media/kunena/js/default-min.js" type="text/javascript"></script>
That's the minimum set needed to run Kunena in J! 2.5. In a "vanilla-flavoured" J 2.5 website using the Beez5 template, the total number of Javascript libraries running (when Kunena is loaded) is 7.
In your case, however, I counted a total of 24 Javascript libraries, any one of which could be responsible for clobbering Mootools in an Internet Explorer environment.
Although I did not encounter any problems (in the 10 minutes that I spent looking at your site) with Firefox - I'm not saying that there aren't Javascript conflicts even for Firefox, it's just that I didn't find any - I did encounter the Javascript errors with IE9. Several elements on your Kunena pages, when clicked, produce the same "Invalid Argument ../media/system.js/mootools-core.js [at] line 354" errors.
What's the solution? Ultimately this is a decision that only you can make. I suggest you read Which came first? The template or the forum? and then look at the practical guide given in msg #1 of Before you post your question, read this first .
When you say "at one point your upgrade failed" I think we should be discussing those issues in a separate topic where we can give it the focus it requires, rather than diffusing the focus away from the principles on which Javascript operates in an Internet Explorer galaxy "far far away". ;)
Last edit: 14 years 4 weeks ago by sozzled. Reason: Corrected URL
The following user(s) said Thank You: mikefriendly
14 years 4 weeks ago #135345 by mo2mo
Replied by mo2mo on topic Javascript pop-up error
i'm just a simple user, maybe thats the reason, but i have no access rights for 'Which came first? The template or the forum?' www.kunena.org/forum/154-miscellaneous-o...emplate-or-the-forum .
Best regards,
mo
14 years 4 weeks ago #135359 by sozzled
I made an error in the URL references earlier. Try it again now.
