Solved CAPTCHA is not properly configured (public key is missing). Please contact site administrator!
I cannot disable (re)captcha Here's my setup:
CAPTCHA Challenge for Guests: No
CAPTCHA Challenge for Users: 0
All reCaptcha keys are empty
The Problem:
Whenever user tries to post message he gets:
Any idea?
Make sure the "CAPTCHA key" fields are empty or use the "Restore Default Settings" feature in the Forum Configuration facility to reset your configuration to their original default settings.
sozzled wrote: I realise the information in K 1.7.1: How to setup CAPTCHA for registered users relates to an earlier version of Kunena, but the principles are similar.
I had the same problem and I found a bug
If the user has posted a message (and the user only have this message) that is waiting for approval by the moderators, the error will happen.
In my case, this person had a message in a moderated forum and was unapproved. He could write in other unmoderated forums but could not do it and that CAPTCHA error appeared. DeleteD the unapproved message and problem solved.
What exact Kunena version are-you using ?
