Solved Pending Messages Doesn't Show
13 years 7 months ago - 13 years 7 months ago #142161 by hkymre
I'm seeing the same issue - 4 posts showing pending, but nothing there when I click the link.
htaccess: Exists | PHP environment: Max execution time: 60 seconds | Max execution memory: 512m | Max file upload: 8M
Joomla default template details : rt_voxel_responsive | author: RocketTheme, LLC | version: 1.3 | creationdate: December 18, 2012
Third-party components: CommunityBuilder 1.9 | UddeIM 2.9
Plugins: Content - Kunena Discuss 2.0.4
Added a post to the form - count goes up to 5, click link & it shows only the new post I made.
Deleted post & count back to 4
Permanently deleted post & count back to 4
Last edit: 13 years 7 months ago by hkymre. Reason: added test results
13 years 7 months ago - 13 years 7 months ago #142162 by xillibit
Are-you looking in your profile to check pending messages ?
Are-you a global moderator, a moderator in a specific category or an admin ?
Last edit: 13 years 7 months ago by xillibit.
13 years 7 months ago #142171 by hkymre
I'm an admin & am seeing the 4 pending message(s) on the index of the forum, under the category description.
The URL for the 4 pending messages is http://mysitename/forum/topics/posts/mode-unapproved/catid-6/userid-0
visiting the link shows
Unapproved Posts
No Posts
0 Topics
13 years 7 months ago #142220 by dianaNashif
We are having the same problem.........shows pending messages, but you click on it and it says Un approved post - No Posts. The posts were there because I added to test posts. At first they did show, I didn't moderate them so I could see if this issue is still happening as my moderators say is has and yes, after a while, the posts do disappear.
Has anyone found a solution to this?
I am signed in a a superAdmin.
Thank you for helping me,
Diana
htaccess: Exists | PHP environment: Max execution time: 30 seconds | Max execution memory: 256M | Max file upload: 512M
Joomla default template details : rt_metropolis | author: RocketTheme, LLC | version: 1.2 | creationdate: February 13, 2013
Third-party components: Jomsocial 2.8.3
Plugins: JomSocial - My Kunena Forum Menu 2.0.4 | JomSocial - My Kunena Forum Posts 2.0.4 | JomSocial - Kunena Groups 2.0.4
Modules: Kunena Latest 2.0.4
13 years 7 months ago #142225 by sozzled
I'm not sure if this will help: try "recount category statistics" and "synch users" (with all options checked).
13 years 7 months ago #142226 by dianaNashif
Hi Sozzled,
Just did what you suggested without any change.
Any other ideas?
Diana
Time to create page: 0.158 seconds
