Question The new Kunena upgrade made my Forums "lightbox" not working
13 years 9 months ago - 13 years 9 months ago #140751 by AddInspiration
In my case it do not work Firefox, chrome or safari :sick:
Last edit: 13 years 9 months ago by AddInspiration.
13 years 9 months ago #140785 by sozzled
AddInspiration: it may help if your post your Kunena configuration report in this topic. Thank you.
13 years 9 months ago #140861 by AddInspiration
Here is my report:
htaccess: Exists | PHP environment: Max execution time: 30 seconds | Max execution memory: 128M | Max file upload: 128M
Joomla default template details : ms_template_header2012_2_5 | author: Add Inspiration | version: 2.0 | creationdate: 2012-04-03
Kunena default template details : ArgentRC Dark | author: Gonzaunit | version: 1.6.0 | creationdate: 2010-08-20
Plugins: JomSocial - My Kunena Forum Menu 2.0.4
13 years 9 months ago - 13 years 9 months ago #140870 by sozzled
I think I know why your lightbox does not work. The Kunena template that you are using was designed (by someone who is not a member of the Kunena project team) for an older version of Kunena. As you can see, this very important point is made in the K 2.0.4 release notes . Your problem should be solved by using the K 2.0 Blue Eagle template. In any event, if you continue to use that out-of-date template, we cannot help you any further with your problem.
You should also uninstall the JomSocial - My Kunena Forum Menu[/u] 2.0.4 plugin. You do not have the JomSocial component installed and therefore you do not need the plugin for it.
Last edit: 13 years 9 months ago by sozzled.
13 years 9 months ago #140944 by Blackwidow
Hi
On my testforum I've made the change to Blue Eagle 2.0 and all works fine now (lightbox). But on my orginal forum it still is not working, even with Blue Eagle 2.0 !! And this is exact copy on both sites... what am I overlooking now ?
13 years 9 months ago #140952 by Blackwidow
Ok solved, i finally got it working! Used 2.0 template, but selected Yes on 'enable lightbox' instead of use normal....
