Solved K 2.0.2 "lost" images
- domenicocg
- Senior Member
11 years 4 months ago #21
by domenicocg
Replied by domenicocg on topic K 2.0.2 "lost" images
Sozzled Hi, thank you for answers. I did a test on my domain host and I faced the same problem.
By Domenico
By Domenico
- domenicocg
- Senior Member
11 years 4 months ago #22
by domenicocg
I have try upgrading the version to 1.5.7 from 1.5.14 and the forum works normal when I go to upgrade from 1.5.4 to 1.6.5 or 1.7. 2 the forum works, the problem that does not exist kunena discuss plug-in not even kunena latest forum. How can I solve the problem of migration from 1.5.14 to 2.0.2!!!!
By Domenico
By Domenico
11 years 1 month ago #23
by mijalis
I found two bugs both in administrator/components/com_kunena/libraries/bbcode/bbcode.php
The solution for me was to modify the following two lines:
I modified line
TO
and
TO
Replied by mijalis on topic K 2.0.2 "lost" images
I had the same problem after upgrading from 1.7 to 2.0.2.domenicocg wrote: Sozzled Hi, thank you for answers. I did a test on my domain host and I faced the same problem.
By Domenico
I modified line
if ($att->filename == $filename && $att->folder == 'media/kunena/attachments/legacy/images') {
if ($att->filename == $filename && $att->folder == '/media/kunena/attachments/legacy/images') {
and
return '<div class="kmsgimage"><img src="' . $fileurl . $width .'" style="max-height:'.$config->imageheight.'px;" alt="" /></div>';
return '<div class="kmsgimage"><img src="' . $fileurl .'"'. $width .'" style="max-height:'.$config->imageheight.'px;" alt="" /></div>';
The following user(s) said Thank You: domenicocg
- domenicocg
- Senior Member
11 years 1 month ago #24
by domenicocg
Thanks for the reply I check'll let you know if I solved it.
By Domenico
By Domenico
11 years 1 month ago #25
by leprikon
Replied by leprikon on topic K 2.0.2 "lost" images
it is super.
thanks
thanks
Time to create page: 0.525 seconds
