Kunena 6.2.6 released
Solved K 2.0.2 "lost" images
- domenicocg
- Senior Member
Why enter twice the same link to view image?
It is very work my forum is big, there some way to do it automatically.
Thanks for the reply. By Domenico
P.S.: sorry for my english
- domenicocg
- Senior Member
Before the date nature everything is working correctly.
By Domenico
Example:
Why does this topic have "K 2.0.2" in the subject if you upgraded to K 2.0.3? I do not know if XMAP works with K 2.0.x
- domenicocg
- Senior Member
I tried several times to install from scratch, but the problem remains. I have always used xmapp for do . Give you me tips to make testing locally?
I think it's a problem of migration.
By Domenico
Perhaps you mean XAMPP? Here is our advice about local testing: Support for PC-hosted websites (e.g. WAMP, XAMPP) . I hope that helps.domenicocg wrote: I have always used xmapp for do . Give you me tips to make testing locally?
I don't think this is just a question of upgrading but it's true that we have had questions from people who have lost images and attachments that were added when they were running really old, outdated and "buggy" versions of Kunena. K 1.5.7 was a buggy version. If these images or attachments are really important then I am sure you will find a way to recover those things.
I have merged this topic with the one in which you originally posted your question. Let's keep the subject (and your problem) together in the one place.
*** Topics merged ***
- domenicocg
- Senior Member
I'm sorry if I opened a new topic.
By Domenico
Further, you may spend more time wrestling with XAMPP than working out the solution to a problem. XAMPP problems may be a distraction from the real issues which are about whether things will work in a production environment.
It may be that you will not have the problems in your hosted environment that you now seem to have in XAMPP. Remember, XAMPP is probably using different versions of MySQL, Apache and PHP to your live site. The folder and file permissions on your XAMPP site may be different too. Different operating systems (Unix compared with Windows). I mean, XAMPP is not the same, is it?
(1) Sometimes people lose images that were attached in posts on older, outdated and buggy versions of Kunena. Not in every case but in some cases. Unfortunately, these things happen. If we knew what version of Kunena you were running before you upgraded we may be able to get a better picture of the problems that people are having.
(2) Somewhere in this forum I posted information that explains how and where Kunena stores attachments. I can't remember exactly where that was. K 2.0 uses a similar storage mechanism to K 1.7. In K 1.7, each user's uploaded images are stored in a separate folder for each user. In K 1.5 images were thrown together in one big folder.
(3) People may have problems uploading images. The folder/file permissions may be "wrong" - see Securing Kunena for more information
(4) People may not be able to upload images or other attachments if the images/attachments are not able to be managed by PHP (in other words, there's no allowance made for the MIME type). Most .jpg, .gif, .png and .txt and .zip files can be handled but if you're using something else, you may have problems. These things are controlled by both the Joomla Global Configuration settings and the Kunena Forum Configuration settings but there may be other factors that involve your hosting platform.
(5) Some problems are common and some problems are unique. It helps when we know what we're dealing with in each case. I remind people to learn the lesson of I have the same problem .
(6) Your configuration report may help. We do not support K 2.0.2. If you are using that version, our advice is to use K 2.0.3 and see if upgrading addresses the problem in a better way.
