Solved Guests cannot read forum topics [resolved]
14 years 1 month ago - 14 years 1 month ago #133843 by sozzled
These settings appear normal to me. Therefore we can eliminate your Kunena menu as the cause of the problems.
You showed the permissions of one category: "COMMUNITY INTEGRA700". What about all the other sections and categories of your forum. What are the permissions on the section "Forum generale della moto Automatiche Honda"? What are the permissions on all the categories and sub-categories in that section?
I still have a suspicion that you've modified Joomla ACL access in some way that is stopping users gaining access but I could be wrong.
We are reaching the stage where we will not be able to help you in a question-and-answer self-help forum and perhaps someone will need to examine everything about your website from the administrator point-of-view.
I would advise you to read When all else fails, try this . Prove to yourself that you can create a Joomla website, install Kunena, make no changes and everything works. If you cannot use Kunena straight "out-of-the-box" then all this fiddling around after you've made I-don't-know-how-many-changes won't help you either.
Last point: try disabling all the Kunena integration plugins. You have enabled all the plugins and many of the settings but you don't even have the required software installed. In effect, you have AlphaUserPoints, Community Builder, JomSocial and Joomla all controlling how your forum behaves. So, what do you really need? Disable the things you don't need.
Last edit: 14 years 1 month ago by sozzled.
The following user(s) said Thank You: nicola dn01
14 years 1 month ago #133846 by rich
Maybe I have found the error. Has your plugin "Kunena - Joomla Integration" acess level registered? Then this error occurs. The access must be public.
14 years 1 month ago #133856 by nicola dn01
rich wrote: Maybe I have found the error. Has your plugin "Kunena - Joomla Integration" acess level registered? Then this error occurs. The access must be public.
I love youuuuuuuuuuu!! :lol: :lol: :lol: We were going crazy!
Sozzled (thank you so much for your time) tried for days the needle in the haystack, and you had the needle in his hand. I've learned that the computer is so: grateful or ungrateful.
Rich, intuition obvious but decisive, !!
The plugin "Kunena - Joomla Integration", has already been the cause of my carelessness, to synchronize users between Joomla and Kunena :) :)
Thank you so much
Ciao
