Solved public (logged out) cant view new replies "permissions problem"
i have been trying this since the weekend and im not able to figure out the correct settings.
Problem:
If you are not logged in, and you try to view a thread
You do NOT see the new replies.
If you are not logged in and you followed a thread update link from your email, you do not see NEW replies.
Of course this is all resolved when you ARE logged in.
I have tried changing a few categories to ACCESS LEVEL and setting them up appropriately but the problem still remains.
Im not sure what to do now and i dont want to completely mess things up.
Problem Description :: Forum Post Assistant (v1.2.2) : 11th September 2012 wrote: public user can not see replies on forum
Log/Error Message :: Forum Post Assistant (v1.2.2) : 11th September 2012 wrote: na
Actions Taken To Resolve by Forum Post Assistant (v1.2.2) 11th September 2012 wrote: attempted to setup correct permissions using ACCESS LEVEL to PUBLIC
Basic Environment :: wrote: Joomla! Instance :: Joomla! 2.5.6-Stable (Ember) 19-June-2012
Joomla! Platform :: Joomla Platform 11.4.0-Stable (Brian Kernighan) 03-Jan-2012
Joomla! Configured :: Yes | Read-Only (444) | Owner: grooveclip.com (uid: 281804/gid: 35680) | Group: grooveclip.com (gid: 35680) | Valid For: 2.5
Configuration Options :: Offline: 0 | SEF: 1 | SEF Suffix: 0 | SEF ReWrite: 1 | .htaccess/web.config: Yes | GZip: 0 | Cache: 0 | FTP Layer: 0 | SSL: 0 | Error Reporting: default | Site Debug: 0 | Language Debug: 0 | Default Access: 1 | Unicode Slugs: 0 | Database Credentials Present: Yes
Host Configuration :: OS: Linux | OS Version: 3.2.6mtv12 | Technology: x86_64 | Web Server: Apache/2.2.22 | Encoding: gzip, deflate | Doc Root: /home/33727/domains/antifmradio.com/html | System TMP Writable: Yes
PHP Configuration :: Version: 5.3.15 | PHP API: cgi-fcgi | Session Path Writable: Unknown | Display Errors: 1 | Error Reporting: 22519 | Log Errors To: | Last Known Error: | Register Globals: 0 | Magic Quotes: 1 | Safe Mode: 0 | Open Base: /nfs:/tmp:/usr/local:/etc/apache2/gs-bin | Uploads: 1 | Max. Upload Size: 2M | Max. POST Size: 8M | Max. Input Time: -1 | Max. Execution Time: 120 | Memory Limit: 99M
MySQL Configuration :: Version: 5.1.26-rc-5.1.26rc-log (Client:5.1.63) | Host: --protected-- (--protected--) | Collation: latin1_swedish_ci (Character Set: latin1) | Database Size: 29.01 MiB | #of _FPA_TABLE: 264Detailed Environment :: wrote: PHP Extensions :: Core (5.3.15) | date (5.3.15) | ereg () | libxml () | openssl () | pcre () | sqlite3 (0.7-dev) | zlib (1.1) | bcmath () | bz2 () | calendar () | ctype () | curl () | dba () | dom (20031129) | hash (1.0) | fileinfo (1.0.5-dev) | filter (0.11.0) | ftp () | gd () | gettext () | SPL (0.2) | iconv () | session () | json (1.2.1) | ldap () | mbstring () | mcrypt () | mysql (1.0) | mysqli (0.1) | standard (5.3.15) | PDO (1.0.4dev) | pdo_mysql (1.0.2) | pdo_pgsql (1.0.2) | pdo_sqlite (1.0.1) | pgsql () | Phar (2.0.1) | posix () | pspell () | Reflection ($Id: e98652ba2326bd9391b730afdaf96c017d9fab48 $) | imap () | SimpleXML (0.1) | soap () | sockets () | SQLite (2.0-dev) | exif (1.4 $Id$) | tokenizer (0.1) | wddx () | xml () | xmlreader (0.1) | xmlrpc (0.51) | xmlwriter (0.1) | xsl (0.1) | cgi-fcgi () | mhash () | Zend Engine (2.3.0) |
Potential Missing Extensions :: zip | suhosin |
Switch User Environment (Experimental) :: PHP CGI: Yes | Server SU: Yes | PHP SU: Yes | Custom SU (LiteSpeed/Cloud/Grid): Yes
Potential Ownership Issues: NoFolder Permissions :: wrote: Core Folders :: images/ (755) | components/ (755) | modules/ (755) | plugins/ (755) | language/ (755) | templates/ (755) | cache/ (755) | logs/ (755) | tmp/ (755) | administrator/components/ (755) | administrator/modules/ (755) | administrator/language/ (755) | administrator/templates/ (755) |
Elevated Permissions (First 10) :: NoneExtensions Discovered :: wrote: Components :: SITE :: Bubble (2.6.2) | Default (2.6.2) | Blackout (2.6.2) | Blueface (2.6.2) | Simplistic (3.5) | Elegentgreen (3.5) | Hako (3.5) | Carbon (3.5) | Elegantblue (3.5) | Default Theme (3.5) | Elegentgreen (3.5) | Polish (3.5) | BlueDream (3.5) | ElegantYellow (3.5) | Pinky (3.5) | Elegantred (3.5) | Plain (3.5) | Hako (3.5) | Bubbles (3.5) | Timeless (3.5) | Greenie (3.5) | com_mailto (2.5.0) | com_wrapper (2.5.0) |
Components :: ADMIN :: com_redirect (2.5.0) | com_installer (2.5.0) | com_users (2.5.0) | com_banners (2.5.0) | com_plugins (2.5.0) | com_categories (2.5.0) | EasyBlog (3.5.12510) | com_checkin (2.5.0) | J2XML Importer (1.6.0.71) | com_kunena (2.0.2) | plg_finder_kunena (2.0.2) | plg_kunena_joomla (2.0.2) | plg_kunena_kunena (2.0.2) | Kunena - Kunena Integration (2.0.2) | Kunena - UddeIM Integration (2.0.2) | plg_kunena_uddeim (2.0.2) | plg_kunena_alphauserpoints (2.0.2) | Kunena - AlphaUserPoints Integ (2.0.2) | System - Kunena Forum (2.0.2) | plg_system_kunena (2.0.2) | Kunena - JomSocial Integration (2.0.2) | plg_kunena_community (2.0.2) | Kunena - Joomla Integration (2.0.2) | plg_kunena_gravatar (2.0.2) | Kunena - Gravatar Integration (2.0.2) | plg_quickicon_kunena (2.0.2) | plg_kunena_comprofiler (2.0.2) | Kunena - CommunityBuilder Inte (2.0.2) | plg_system_kunena (-) | Kunena Menu (2.0.2) | mod_kunenamenu (2.0.2) | COM_ADVANCEDMODULES (3.1.2PRO) | com_languages (2.5.0) | com_zoo (2.6.2) | com_stectechimageslider (1.0) | Akeeba (3.6.3) | com_messages (2.5.0) | com_weblinks (2.5.0) | com_cache (2.5.0) | com_media (2.5.0) | com_login (2.5.0) | com_finder (2.5.0) | FlexBanners (2.0.| com_content (2.5.0) | JomSocial (2.6.2) | com_config (2.5.0) | com_modules (2.5.0) | com_templates (2.5.0) | com_admin (2.5.0) | com_joomlaupdate (2.5.0) | com_newsfeeds (2.5.0) | MusCol (2.2.2) | com_cpanel (2.5.0) | com_search (2.5.0) | com_menus (2.5.0) |
Modules :: SITE :: mod_articles_news (2.5.0) | Activity Stream (2.6.2) | mod_articles_category (2.5.0) | ZOO Tag (2.5.0) | Featured artists (2.2.0) | Custom Twitter Slider (1.0) | mod_footer (2.5.0) | Upcoming Events (2.6.2) | Music Collection Statistics (R (2.2.1) | EasyBlog Showcase (3.5.4) | Hello Me (2.6.2) | Active Groups (2.6.2) | Music Collection Search Bars (2.2.0) | mod_login (2.5.0) | Recently added albums (2.0.0) | mod_menu (2.5.0) | Stectech Nivo Slider (1.0) | EasyBlog Most Commented Post (3.5.4) | Latest group posts (2.6.2) | mod_stats (2.5.0) | mod_articles_archive (2.5.0) | Top Members (2.6.2) | Music Collection Statistics (E (2.1.1) | ZOO Comment (2.6.0) | mod_articles_categories (2.5.0) | Stectech Image Slider (1.0.stable) | mod_kunenalatest (2.0.2) | JW Player MODULE for Music Col (2.2.2) | Online Users (2.6.2) | Random and Featured Albums (ch (2.0.0) | mod_users_latest (2.5.0) | EasyBlog New Post Module (3.5.4) | mod_wrapper (2.5.0) | Top viewed artists, albums and (1.5.0) | mod_related_items (2.5.0) | FlexBanners (2.0.| Video Comments (2.6.2) | Latest Members (2.6.2) | EasyBlog Tag Cloud (3.5.4) | EasyBlog Post Map (3.5.4) | mod_whosonline (2.5.0) | EasyBlog Subscribers (3.5.4) | EasyBlog Latest Bloggers (3.5.4) | ZOO Category (2.5.0) | Top rated albums (2.2.0) | mod_breadcrumbs (2.5.0) | ZOO Item (2.6.0) | Recently added artists (1.1.0) | mod_finder (2.5.0) | Recent Comments (3.5.4) | Blog Categories (3.5.4) | EasyBlog Welcome (3.5.4) | Jomsocial Notification (2.6.2) | Music Collection Letter Bar (2.1.0) | mod_random_image (2.5.0) | Custom Facebook Slider (1.0) | mod_banners (2.5.0) | Team Blogs (3.5.4) | mod_syndicate (2.5.0) | Photo Comments (2.6.2) | Latest Discussion (2.6.2) | EasyBlog Image wall module (3.5.4) | mod_languages (2.5.0) | EasyBlog Calendar (3.5.4) | EasyBlog Subscribe Module (3.5.4) | EasyBlog Biography module (3.5.4) | Recently added songs (2.0.0) | mod_feed (2.5.0) | EasyBlog Most Popular Post (3.5.4) | JomSocial Connect (2.6.2) | mod_sw_kbirthday (1.8.
| mod_articles_latest (2.5.0) | EasyBlog Top Blog Entries (3.5.4) | EasyBlog Random Post (3.5.4) | EasyBlog Most Active Bloggers (3.5.4) | mod_articles_popular (2.5.0) | EasyBlog Latest Blogs (3.5.4) | mod_search (2.5.0) | EasyBlog Archive (3.5.4) | mod_weblinks (2.5.0) | mod_custom (2.5.0) | JomSocial Statistics (2.6.2) |
Modules :: ADMIN :: mod_version (2.5.0) | mod_feed (2.5.0) | mod_custom (2.5.0) | mod_status (2.5.0) | mod_popular (2.5.0) | mod_menu (2.5.0) | mod_quickicon (2.5.0) | mod_toolbar (2.5.0) | mod_submenu (2.5.0) | mod_multilangstatus (2.5.0) | mod_latest (2.5.0) | ZOO Quick Icons (2.5.0) | mod_title (2.5.0) | mod_login (2.5.0) | mod_logged (2.5.0) |
Plugins :: SITE :: plg_kunena_alphauserpoints (2.0.2) | plg_kunena_joomla (2.0.2) | plg_kunena_comprofiler (2.0.2) | plg_kunena_gravatar (2.0.2) | plg_kunena_uddeim (2.0.2) | plg_kunena_kunena (2.0.2) | plg_kunena_community (2.0.2) | plg_editors_codemirror (1.0) | plg_editors_tinymce (3.5.2) | Latest Photos (2.6.2) | Unknown (-) | My Latest Videos (2.6.2) | Unknown (-) | My Contacts (2.6.2) | My Albums (1.0) | My kunena updates (2.6.2) | Unknown (-) | My Tagged Videos (2.6.2) | Events (2.6.2) | Events (2.6.2) | Unknown (-) | My twitter updates (2.6.2) | Unknown (-) | Friend's Location (2.6.2) | Walls (2.6.2) | Log (2.6.2) | Input Processor (2.6.2) | Wordfilter (2.6.2) | plg_editors-xtd_image (2.5.0) | plg_editors-xtd_article (2.5.0) | plg_editors-xtd_pagebreak (2.5.0) | Editor Button - My Photos (2.6.2) | plg_editors-xtd_readmore (2.5.0) | PLG_EDITORS-XTD_MODULESANYWHER (2.3.0FREE) | plg_authentication_joomla (2.5.0) | plg_authentication_gmail (2.5.0) | plg_authentication_ldap (2.5.0) | Muscol - JW Player (2.2.2) | User - Jomsocial User (2.6.2) | User - EasyBlog Users (3.0.0) | plg_user_contactcreator (2.5.0) | plg_user_joomla (2.5.0) | plg_user_profile (2.5.0) | Azrul System Mambot For Joomla (2.6.2) | plg_system_logout (2.5.0) | System - Disable Mootools (1.0.1) | plg_system_highlight (2.5.0) | System - Zend Lib (1.11.4) | System - ZOO Event (2.5.0) | plg_system_debug (2.5.0) | plg_system_p3p (2.5.0) | plg_system_cache (2.5.0) | Jomsocial Update (2.6.2) | plg_system_log (2.5.0) | plg_system_sef (2.5.0) | PLG_SYSTEM_MODULESANYWHERE (2.3.0FREE) | plg_system_kunena (2.0.2) | plg_system_languagecode (2.5.0) | plg_system_redirect (2.5.0) | jomsocialredirect (2.6.2) | plg_system_languagefilter (2.5.0) | System - Jomsocial Facebook Co (2.6.2) | plg_system_remember (2.5.0) | PLG_SYSTEM_NNFRAMEWORK (12.9.6) | PLG_SYSTEM_ADVANCEDMODULES (3.1.2PRO) | plg_extension_joomla (2.5.0) | plg_content_pagebreak (2.5.0) | plg_content_geshi (2.5.0) | plg_content_kunenadiscuss (2.0.2) | plg_content_emailcloak (2.5.0) | Content - Show album (1.1.0) | plg_content_pagenavigation (2.5.0) | plg_content_vote (2.5.0) | plg_content_joomla (2.5.0) | plg_content_loadmodule (2.5.0) | Content - ZOO Shortcode (2.5.0) | plg_content_finder (2.5.0) | plg_captcha_recaptcha (2.5.0) | PLG_JMONITORING_AKEEBABACKUP_T (1.0) | Smart Search - ZOO (2.5.0) | plg_finder_categories (2.5.0) | plg_finder_newsfeeds (2.5.0) | plg_finder_weblinks (2.5.0) | plg_finder_content (2.5.0) | plg_finder_contacts (2.5.0) | ZOO Search (2.5.0) | plg_search_content (2.5.0) | plg_search_contacts (2.5.0) | plg_search_categories (2.5.0) | plg_search_newsfeeds (2.5.0) | Search - Albums (2.2) | plg_search_weblinks (2.5.0) | plg_quickicon_extensionupdate (2.5.0) | plg_quickicon_kunena (2.0.2) | plg_quickicon_joomlaupdate (2.5.0) |Templates Discovered :: wrote: Templates :: SITE :: beez_20 (2.5.0) | beez5 (2.5.0) | atomic (2.5.0) | gk_twn2 (2.
Templates :: ADMIN :: bluestork (2.5.0) | hathor (2.5.0) |
in my email i got this link about a reply
www.antifmradio.com/radio/forum/news-dis...ack-in-business/3515
it should goto a post numbered as #3515
but as you can see, that post # is not there.
And you can see that because im sure anyone from this thread is NOT a member of the site and therefore not logged in
that one is about SOMETIMES and mine is all the time if you are not logged in.
Also, i read that topic already as well as topics in the DOCUMENTS, FAQs and i think 11 other topics in the forums just today.
Ok so that aside, here is what i am wondering
I have a plugin called
In it is a setting called "Enable Access Control"
I had it previously set to YES
I changed it to NO just now but have yet to test the issue
Could this have been my problem and
if i set it to NO
then when i goto CATEGORY MANAGER
Click on a CATEGORY
click on PERMISSIONS tab
what should i be using for "Access Control Type::
Post a picture of your Permissions tab in one of those categories that you cannot access.
sozzled
ill get to the 1st two things you mention tomorrow when i get up again
however,. about the last item
i dont think you are understanding me correctly
i never said i cant access them.
i said, the visitor (when not logged in) or member (when not logged in)
can not see the NEW REPLY
they can see the original post, the thread, the categories, and the entire forum
but can not see the REPLY message
