Solved How do I get my RSS to work the way I expect it
14 years 3 months ago - 14 years 3 months ago #132279 by sozzled
There was no sarcasm. It's just that for me to locate the information and post the specific details for you takes me 3 minutes to locate them and 5 minutes to post the details and I was being lazy, hoping that you would do some of the work yourself.
The setting is:
Forum configuration » Security » Security Settings » E-mail Administrators = All New Posts
Last edit: 14 years 3 months ago by sozzled.
14 years 2 months ago #132322 by gordonrobb
Wow! If only you knew how much time I had spent pouring over those settings. I actually looked at that one and took it as something for errors (not looking at the different options it had). My problem was that I couldn't find any mention of it in the documentation (perhaps I missed it there too :)).
Anyway, thanks for your help on this. Done and testing and it works.
Any pointers on getting the RSS set up? Just in case users want to ask me how to make it work?
14 years 2 months ago #132324 by sozzled
It depends, really, on how you want RSS setup. Do you see the RSS feed on this site? Does that meet your needs?
14 years 2 months ago #132331 by gordonrobb
Not sure what I should be seeing. I've set it to 'by post' and RSS 2.0 and the little RSS icon appears on the site at the bottom.
If I right click and copy the URL, I have successfully set up up the feed in Outlook, and when I did that I got the posts that were there when I set it up. I haven't had anything show up in outlook since though. My thought was that what it would do is new posts would appear in the RSS feed part of outlook, but it isn't doing that.
14 years 2 months ago - 14 years 2 months ago #132352 by sozzled
gordonrobb wrote: My thought was that what it would do is new posts would appear in the RSS feed part of outlook, but it isn't doing that.
I do not understand what you mean, exactly. If I have interpreted correctly, I think you're expecting your website to "push" notification of new forum messages to you - in a similar manner to sending email to you. If you are expecting that websites are continually updating RSS feeds whenever there is new contect and that, somehow, your site will "update" the RSS feed when there are new messages on your forum and then ontact your RSS feed viewer with "wake-up there is some news for you to read" alert, then I think don't understand how RSS works
RSS does not "push" notifications in the same manner as email. Your RSS viewer "pulls" new RSS information when you decide to "pull" it; this could be when you click a button or every hour or two. Most RSS viewers refresh the RSS information on an time basis (e.g. every hour). This means that, once an hour, your RSS viewer contacts the site and asks "have you got an RSS update for me?" Then, the contents of your RSS is replaced with whatever new information is obtained from your website.
I asked you, in my last reply, whether the RSS feature used at this site ( www.kunena.org ) was the way you want things to work at your site. You did not answer my question.
As I mentioned in msg #2 of this topic, we may have had better answers to your question if you had followed the instructions in the Guide to posting questions when asking for support that appears on the Index page of this forum. Without knowing your forum configuration I can only offer you my general (theoretical) understanding about how things are supposed to work (supported, in part, by a practical demonstration of Kunena at K.org).
Is this - how things work at K.org - how you might expect RSS to work for you? :dry:
I do not know why your site (wherever it is) is not working as you would expect.
Last edit: 14 years 2 months ago by sozzled.
14 years 2 months ago #132375 by gordonrobb
It feels like I'm being in some way critisised for asking for help. I'm sorry if this is not how things should be done here. I'm used to forums that you can ask for help, and you get an answer or pointed in the right direction.
I explained in my first post I am a noob at this. I only have subscription to 4 other RSS feeds. How I got them wsa to click on the RSS icon n their site and it gave me the option of how I wanted to subscribe - I picked google reader. In google reader I exported the feed and I ported them in Outlook. When there's a new post (they are blogs) it appears in there've, like a new email. If outlook is going out to get them, I didn't set it up that way, but I'll have a look to see if there is a setting.
My point in this thread was it didn't seem to work the way I expected, which is, I click in it, and it asks me how I want to subscribe. I got it manually set up but doesn't update and I can't see a way to tell outlook to go get it - although I will look again.
I haven't subscribed to this forums rss, but will give that a go. Sorry if I'm going about this all the wrong way. I'm not sure what I'm doing, which is why I'm looking for some help.
I hadn't read that part you directed me to as it was in the part of the forum I first posted in, which you told me was the wrong part. I have now and here is my config report.......
htaccess: Missing | PHP environment: Max execution time: 30 seconds | Max execution memory: 128M | Max file upload: 2M
Joomla default template details : beez5 | author: Angie Radtke | version: 2.5.0 | creationdate: 21 May 2010
Kunena default template details : Blue Eagle 2.0 | author: Kunena Team | version: 2.0.1 | creationdate: 2012-07-07
Plugins: None
Modules: Kunena Stats 2.0.1
Time to create page: 0.151 seconds
