Solved How do I get my RSS to work the way I expect it
14 years 2 months ago - 14 years 2 months ago #132399 by sozzled
Thank you for posting your configuration report which also provides us with the key information to help us to pinpoint the problems you are having. I can see that you do not have any "meaningful" RSS fees data when you click the RSS icon at the bottom of your main page.
I was not criticising you in any way. I was only trying to identify the cause of the problem and I hope we will be able to get to the heart of the matter more quickly now.
Typically - and I mean in the sense if you do not make any changes to the forum configuration from the way that it's setup by default - the RSS feed should work without any problems. Problems usually occur when people change the configuration settings.
These are the RSS configuration settings that you are using:
Forum Configuration » RSS » RSS Settings:
RSS Feed type = By Post
RSS Specification = RSS 2.0 (default)
RSS History (timelimit) = 1 months (default)
RSS Limit = 100 (default)
Include Categories = <null> (default)
Exclude Categories = <null> (default)
Render HTML & BBCode in RSS feeds = Yes (default)
Author Format = Name (default)
Render Author in Title = Yes
Limit Number of Words Per Item = 100
Use Oldstyle Titles = Yes
Caching Interval = 0
The items that I've highlighted in red, above, are the changes that you have made. It may be advisable to restore your configuration settings back to their defaults to see if this fixes the problem and then, if necessary, make changes one by one, to see if one of the changes you've made causes things to go awry again.
Intuitively, one would not expect problems with the way you have set your RSS settings. However, with 12 parameters and several possible options for each, to verify that certain combinations of these options cause problems could take hundreds of hours to check each combination. At this website here ( www.kunena.org ) we use the default settings. That's why I asked you a couple of times earlier in this topic if it may be useful to you know how we've set things here at this site and whether the RSS feed that's generated by this forum (at www.kunena.org ) would be a useful solution to you? I have not verified, personally, if the combination of settings you're using causes problems. It's possible that your particular combination is "broken" but it may depend on other factors that we have not yet identified.
I would suppose that, from a theoretical view, using your settings, the two messages posted in your Welcome Mat category should have appeared in your RSS feed. My use of RSS in Kunena is not exhaustive. I tend to leave configuration settings alone, for the most part. :)
Importantly, however, you have created a section in your forum that has no categories. Under this arrangement, people cannot post new topics into the section "Programme Specific Forums" because there are no categories for them to be able to use. I suggest you read the preamble in Sections, Categories, sub-Categories (Part 1) to fix that issue.
(Off-topic): It may also help to read the article Search Engine Optimisation (SEO) and implement the recommendations that we've offered in that guide. ;)
No criticism of the way you've done things. We're only trying to help as efficiently and effectively as we can. :)
Last edit: 14 years 2 months ago by sozzled.
14 years 2 months ago #132400 by gordonrobb
I'll take a look at those changes. I wasn't aware that I had changed anything other than the 'by post' part. If I do the 'restore defaults' will it restore all of my settings, or just the RSS parts?
When you say, I have a section without categories, do you mean because you are looking at the forums? There are three categories in that section but visibility/access to them is controlled by user group settings. The people that have access to them can post. Or did you mean something else?
Do you know if this should work if I setup the RSS feed in Outlook, it should 'poll' the site and get any new posts?
14 years 2 months ago - 14 years 2 months ago #132401 by sozzled
gordonrobb wrote: When you say, I have a section without categories, do you mean because you are looking at the forums? There are three categories in that section but visibility/access to them is controlled by user group settings. The people that have access to them can post.
This is critical to understanding how RSS feeds work.
Because an RSS feed is, in a way, a "look" into your forum from a mechanism that does not login to your site to get the information, the RSS feed is a bit like a guest looking at your forum to see what they can see. It's a bit like asking Google to index your site; Google cannot go into those areas that are private (i.e. protected by Joomla ACL security). The RSS feed cannot do this, either.
I am sure we have discussed this issue on many occasions here at K.org. As one example, read my comment here: [Merged topic] Kunena RSS feed does not work with Registered Users-only forum
gordonrobb wrote: If I do the 'restore defaults' will it restore all of my settings, or just the RSS parts?
All of your forum configuration settings will be reset to their original default values but this does not affect other areas of your control panel (e.g. categories). Therefore, your category settings will be unaffected. I hope that helps.
The following user(s) said Thank You: gordonrobb
14 years 2 months ago #132403 by gordonrobb
You've solved my problem. Just tired posting a couple of new posts in the public part of the forum and it appears in outlook's rss part straight away. So its because these parts are not public. I'll just not use RSS feed then as these sections need to be hidden from all but the people that can post in them. I'll just suggest that they subscribe to the categories if they want to be informed when people post new threads.
Thanks for your help.
14 years 2 months ago - 14 years 2 months ago #132404 by sozzled
gordonrobb wrote: I'll just suggest that they subscribe to the categories if they want to be informed when people post new threads.
Absolutely! :)
