Solved Cannot see module positions
14 years 2 months ago #132542
by butchjax
Replied by butchjax on topic Cannot see module positions
What I'm saying is no Kunena templates are an option. Only Joomla templates. See the screen capture, those are all only Joomla templates.
14 years 2 months ago - 14 years 2 months ago #132543
Replied by sozzled on topic Cannot see module positions
What **I** am saying is this:
For the module you want to publish a module using the Joomla Module Manager (let's say you want to publish it in the postion "kunena_profilebox") then enter (type) kunena_profilebox in the module position name. Try it.
Last edit: 14 years 2 months ago by sozzled.
The following user(s) said Thank You: butchjax
14 years 2 months ago #132544
by butchjax
Yes, it works. But having to look up a position and type it in is poor programming on someone's end. Perhaps something isn't communicating well. Either way, this is a workaround and should be added to the list of things to fix for future versions. Especially since the document does not say to type in these positions for version 1.7+, something has to change. If this is a known issue, it needs to be documented somewhere until it doesn't need to be done anymore. I mean, I spent days trying to get this worked out between this forum and the theme's forum. It should be easily found. That cuts down on you having to repeatedly explain it as well. And I figure, anything that reduces your workload is a plus.
14 years 2 months ago #132545
This is not poor programming on "someone's" part. There are certain limitations that we all have to live within that are defined by Joomla. Perhaps if Kunena was a free-standing forum product then we would not be thus constrained but, as Kunena is not a free-standing forum product and relies on Joomla, there are some things we cannot easily change.
The module position behaviour - having to type the name - has been the same throughout the whole of the Kunena (and Fireboard before it) project. Nothing has changed here except for the names of the module positions themselves. In that respect, the Wiki article that you've been using is up-to-date.
If you believe that you can contribute more to improving the quality of the Kunena documentation, then we would be grateful for any assistance that you can provide.
Thanks for your feedback. I'm pleased that we were able to resolve this matter fairly quickly - it just needed a little extra "pointing in the right direction"
That's really all that matters.butchjax wrote: Yes, it works.
