Solved Cannot see module positions
14 years 2 months ago #131918 by hdavy2002
Hi all,
I have the latest Kunena installed and with the Joomla 2.5.6
I am trying to add some google adsense, but cannot see any module positions.
kunena_profilebox
kunena_announcement
kunena_bottom
kunena_msg_1 ... kunena_msg_n, where n = number of messages in a page
I re-installed it and same results. I tried to add it manually but no luck.
Any suggestions?
Thanks all for reading and replying.
Cheers
14 years 2 months ago #132424 by xillibit
You need ot publish a module in these positions to have something : docs.kunena.org/index.php/Module_Positions
14 years 2 months ago #132538 by butchjax
How can you publish something to those modules if they aren't available to publish to? I have the same problem as the original poster. I've attached a screen capture of where these module positions should be. I have no filters applied. I got a workaround from my template developer to make sure I had a login module on the forum page, but I can't do anything else because the modules aren't an option. This happened when I upgraded.
14 years 2 months ago #132539 by sozzled
Replied by sozzled on topic Cannot see module positions
Enter the name of the module position. See xillibit's guide. Just because you cannot "see" the names of the extra module positions, this does not mean that they're not there.
14 years 2 months ago #132540 by butchjax
Why wouldn't they be in the list? That's a very inefficient way to set things up, because that means I have to keep referring back to that web page in order to do things. Isn't this a bug if they aren't showing up?
14 years 2 months ago - 14 years 2 months ago #132541 by sozzled
Your site template's module positions are visible. Let's leave aside the question of "efficiency" for a moment; have you tried entering the Kunena Blue Eagle module position against the name of the module you want to publish? Does it work for you? Yes/No?
This is not a bug. This is arguably a weakness in the design of Joomla.
Last edit: 14 years 2 months ago by sozzled.
