Solved How can I switch the languages in Kunena
14 years 3 months ago #131090 by raynald
I have the Joomla language switcher configured with EN (UK) and (FR)
I have installed the French Kunena language file
I have set up a menu for French that is supposed to open Kunena home in french
But what I only get is kunena pages in English.
So, how do you do to have Kunenan switching languages along with the joomla language switcher ?
14 years 3 months ago #131107 by John
The language is triggered by your joomla setting, have you set your front-end language to French in your own profile?
14 years 3 months ago #131108 by raynald
John, could you explain this to me ? I started to learn joomla 5 days ago so I really don't know what you are talking about ;-)
I have activated the language switcher and I switch from language to language (as a matter of fact, the joomla pages that are localized, such as Login form for instance, do work correctly : when I click on the french flag, I do have them in French) but it doesn't seem to have any effect on KUNENA. So I guess something is missing...
14 years 3 months ago - 14 years 3 months ago #131110 by John
Sure, no problem.
- in the tabs above the forum press Profile
- In the blue header press edit (on the right side)
- Find Global Settings - edit Front End Language to French
- Press Save
(you can also do this in the backend - login- Website - My Profile)
Last edit: 14 years 3 months ago by John.
14 years 3 months ago #131116 by raynald
I don't have tabs above my forum. Ho do you display them ?
What I did :
I created a new menu item and selected a link to a Kunena module "Show Category". Even if I force the language to french it displays in english
14 years 3 months ago - 14 years 3 months ago #131117 by John
This link will help you publish your forum menu: www.kunena.org/forum/K-2-0-General-Quest...rum-in-Joomla#131060
You will have to proparly setup your website before fiddling with languages. Make sure your forum works, you have all menu's and Kunena menu is working and only then worry about your language.
