Solved How to display Kunena Forum in Joomla?
14 years 3 months ago #131046 by Patrej
Hello, exuse me for maybe very silly question, but havent find anything about this topic in FAQ.
I have installed newest Kunena and then only one component - Kunena 2.0. I can see Kunenea settings in the menu (attachment) but I cant find the way how to DISPLAY or INSERT Kunena forum on the site itself. I do not know if it has specific URL on the site or if I need to insert it as a Template? I have tried to find it as a category without success.
I believe that answer is very simple or maybe my installation of Kunena was not successfully completed. I would like to display Kunena Forum on the homepage and still dont know how to do this.
Again my appologies for such a stupid thread.
14 years 3 months ago #131060 by sozzled
G'day, Patrej, and welcome to Kunena.
There's no such thing as a stupid question - we all have to start somewhere and no-one learns if we don't ask questions. I hope my answer will be helpful to you.
Most Joomla [component] extensions need a menu item to "drive" them. When you install Kunena, a menu item is created for you (but the item is not published ... it's not "activated" until you publish it).
I agree with you that the K 2.0 Installation Guide is incomplete (and you have my apologies for that). If you use your Joomla Menu Manager, you will find in your default menu that there's an unpublished item called "Forum"; publish that item and I think you'll find that you will be able to get into your forum without too many more worries. I hope that helps. :)
The following user(s) said Thank You: Patrej
14 years 3 months ago #131145 by Patrej
Thanks much for your advice, it worked well :) And yes maybe it would be good to describe also these "baby steps" for beginner users like me. But it is great that one can ask you directly - including such a basic questions.
