Solved After menu fix I can no longer log in
If, on the other hand, I was to try to login with your account and, like you, I failed, then I would have to agree with you that there's an issue with your ability to login. We need to identify the specific problem. If there's a problem with your login, what's different about it compared with someone else's login? No sarcasm here; it's all perfectly reasonable problem analysis.
I'm just trying to make sure I know what kind of problem we're dealing with. Is this a Kunena problem, a Joomla problem or a "something else" problem (e.g. the browser). You see, we could be dealing with dozens of possible factors and we need to eliminate all the possibilities until, as Sherlock Holmes said, "whatever is left, no matter how improbable, is the solution".
For that same reason now I'm back from work I started to test things myself to try to help identify if this is something I do wrong or if this is coming from another direction.
Macbook Pro 01 / Mountain Lion
Macbook Pro 02 / Mountain Lion
Macbook 03 / Lion
Working my wat through this and disabling plugins I think solved the situation. I have a plugin installed called EU e-Privacy Directive and is meant to make my website compliant with the European Cookie Law. What I noticed was that on all the browsers showing this problem, the Cookie Warning was not showing. Disabling this immediately made the login form back working. Maybe a login cookie was being blocked? But still this only happens with new browsers and only on the new Mountain Lion.
Again, it seems like the problem wasn't Kunena. Thanks so far and sorry for taking your time.
If your users login to your site using the forum on the forum (on the site home page) and they never see the Kunena Login module, then you don't even need the Kunena Login module and it will probably be one less headache for you if you uninistall the Kunena Login module. Yes?
The reviews for EU e-Privacy Directive seem quite up-beat and so I don't quite know how to explain how Kunena is involved. The question we need to resolve is whether you're using the Kunena Login module or you're just using the normal login form that appears at the top of the Kunena forum page. That's really the question here.
Then this has nothing to do with the separately-installed Kunena Login module. You can safely uninstall the Kunena Login module because you are not using it.DTP2 wrote: I only use the one on top of my forum ...
