Question AVATAR
14 years 4 months ago #127637
by mcmoody
I deleted everything to do with CB - although when I installed CB, it was specifically because I couldn't figure out how to get Kunena to change the avatar. So I think the problem predated my CB installation.
My Kunena Integration says YES to both profiles and avatars. I checked that a few times.
And I disabled all the plugins for third parties like Jomsocial and CB.
I also tried another browser, but no luck.
Where do you normally look to find the 'avatar' control in Kunena?
martha
martha
The topic has been locked.
14 years 4 months ago #127935
by mcmoody
I have the avatar integration turned in. The profiles turned on. All jomsocial/CB stuff turned off, etc... this happened when I upgraded to 2.0. My avatar picture disappeared and there is no way on the back end or front end to change it?
Martha
Martha
14 years 4 months ago #127940
by mcmoody
Here is a screen shot of what I see. The integration is ON, the profile view has no tabs for avatar? None of the tabs, or the EDIT link, brings you to a place that allows you to change an avatar. And my avatar on the website has been changed to that blue icon - I previously had a photo there before I upgraded. This is where I'm stumped. I have really no other extensions on this website. It's a fresh installation of everything. It does nothing but run this forum.
martha
martha
14 years 4 months ago - 14 years 4 months ago #127951
by billg
(sorry for loss of context - this was in response to GoremanX's suggestions.)
I tried this (already was configured that way), and didn't see any difference. I do have the Gravatar integration turned on. If I turn that off, I get a 500 error:
Fatal Error: Cannot pass parameter 2 by reference in components/com_kunena/lib/kunena.file.class.1.6.php on line 60
Thanks!
Thanks!
Last edit: 14 years 4 months ago by billg.
14 years 4 months ago #127958
by billg
Ahhh...
I see that the problem I get (posted above) when I turn off the Gravatar integration is in the Known Issues for the 2.0 release. I tried the simple fix for that issue (trivial edit to the file mentioned in the error message) and the error went away. Now I can turn off all the integrations in the plug-in manager, particularly the Gravatar integration, and I am able to edit my avatar image.
Problem solved!
Problem solved!
