Question AVATAR
14 years 4 months ago #127459 by emino70
AVATAR was created by emino70
Please, can someone say me why I can't upload an avatar on the user profile? where is I have to look for ? I can't find in my website and in this site too
I posted this topic hours ago but someone deleted it. Can I know why it was deleted? Did I wrong something? Many thanks
The topic has been locked.
14 years 4 months ago #127491 by mcmoody
Replied by mcmoody on topic AVATAR
I've asked the same question today. I'm also confused? It should be really obvious. I can't find it on this help forum and I can't find it on my own forum. I've got avatars enabled....
14 years 4 months ago #127516 by sozzled
Replied by sozzled on topic AVATAR
You have posted your message in the General Talk about Kunena category. Can I assume that you are having problems uploading your avatar to this website ( www.kunena.org ).
Your other topic was not deleted; it was simply moved to a different category because it also did not make this clear to us what you were talking about. However, it did seem to me that you were having an unspecified problem either with (a) your own website or (b) using the Kunena user profile editing features on this website.
14 years 4 months ago #127520 by mcmoody
My problem is, I literally don't see where the "upload" or "add" avatar button is in the profile manager. I'm looking on this forum, thinking maybe my own site was just broken, and I can't find it for me profile here, either. I've looked around in the edit profile section and all the tabs on the profile section. Where do you go to edit your avatar?
martha
14 years 4 months ago #127552 by billg
Replied by billg on topic AVATAR
I have the same problem. I don't see any way to set or change the avatar when I edit a user profile. Latest Joomla 2.5.6 and latest Kunena 2.0. I have config options turned on to allow users to upload an avatar and to use the gallery. The users are created from my site login/account and access to my forum menu item is set to registered users, if it matters.
Thanks!
Bill
Here are my config settings:
htaccess: Missing | PHP environment: Max execution time: 30 seconds | Max execution memory: 128M | Max file upload: 2M
Joomla default template details : shaper_simplicity_ii | author: JoomShaper.com | version: 1.5.0 | creationdate: Jan 2011
Kunena default template details : Blue Eagle 2.0 | author: Kunena Team | version: 2.0.0 | creationdate: 2012-06-27
Kunena version detailled: Kunena 2.0.0 | 2012-06-27 [ Diplomatia ]
| Kunena detailled configuration:
| Joomla! detailled language files installed:
Plugins: None
14 years 4 months ago - 14 years 4 months ago #127575 by GoremanX
Replied by GoremanX on topic AVATAR
Please go to the Joomla Plugin Manager and ensure that the Kunena integration is enabled. Also, in the Kunena Integration plugin options, ensure that "Enable Kunena Avatars" is set to yes.
If you use a third party community component (like Community Builder or JomSocial), then it might be hindering this feature. In that case, the avatar is typically changed through CB or JS, not the Kunena profile.
Here at kunena.org, avatars are currently handled through JomSocial, which is why there's no place to upload avatars when you edit your Kunena profile. You need to click the "People" menu item and change your avatar there. There are plans to change this in the near future.
www.friendlyphotozone.com
Last edit: 14 years 4 months ago by GoremanX.
