Solved Emoticons not showing in backend...
14 years 4 months ago #127455 by fribse
In the emoticon manager I see this:
In the frontend I see this:
In 1.7.2 I had my own template with animated emoticons, and I haven't moved that to 2.0 yet, not sure if that can affect this?
Best regards
Fribse
Dykkerklubben Dannebroge www.dkdb.dk
We're a volunteer driven diving club in Mosede, Denmark.
Har du brug for en dykkerklub der rummer alle, så kom ned til os.
14 years 4 months ago #127602 by Matias
Its probably your custom emoticons. Please copy those to /media/kunena/emoticons after upgrading to K2.0.1 (should be out in few days).
14 years 4 months ago - 14 years 4 months ago #127642 by fribse
Ok, do I understand you right, that it will work only after 2.0.1? :-)
And this is /media under joomla, and not /administrator/components/com_kunena/media, right?
Best regards
Fribse
Last edit: 14 years 4 months ago by fribse.
14 years 4 months ago #127670 by Matias
Yes, under media. I'm not sure if it works now, you can try.. Another possibility is to create new template with new icons in it.
The following user(s) said Thank You: fribse
14 years 4 months ago #127801 by fribse
Where do I find an explanation about hot to create the template?
I would like to create my own, based on bluebird, like I did for 1.7.
But I'm unsure as to how, the only dog I have is for at 1.7 template.
Oh, it would be nice with a tool for building a template, I know, it just luxury, but nevertheless :-)
Best regards
Fribse
14 years 4 months ago #127815 by Matias
Time to create page: 0.222 seconds
