Solved 500 Error for registered users
14 years 4 months ago #126896 by Pinkeltje
htaccess: Exists | PHP environment: Max execution time: 300 seconds | Max execution memory: 128M | Max file upload: 32M
Joomla default template details : joomlanl | author: Angie Radtke | version: 1.7.0 | creationdate: 25 November 2009
Kunena version detailled: Kunena 2.0.0 | 2012-06-27 [ Diplomatia ]
| Kunena detailled configuration:
| Joomla! detailled language files installed:
Third-party components: Jomsocial 2.4.3
Plugins: Search - Kunena Search 1.7.0 | JomSocial - My Kunena Forum Menu 2.0.0 | JomSocial - My Kunena Forum Posts 2.0.0 | JomSocial - Kunena Groups 2.0.0
Modules: Kunena Latest 2.0.0 | Kunena Stats 2.0.0 | Kunena Login 2.0.0 | Kunena Search 2.0.0
No problem for moderators to insert images and links, but when doing this as a registered user it generates a 500 error. Update from Kunena 1.7.2 and no settings are changed.
Could this be a bug or has it something to do with settings.
Apache error log generates:
File does not exist: path-to/components/com_kunena/template/blue_eagle/js/mediaboxAdv.js
File does not exist: path-to/components/com_kunena/template/blue_eagle/js/default-min.js
And file does not exist. But I suppose error should occur for moderator as well?
14 years 4 months ago #126897 by 810
Replied by 810 on topic 500 Error for registered users
please remove the js dir on your own template.
We changed a lot of js. so it doenst work anymore. The default js will be loaded. when you delete the dir.
Regards 810
14 years 4 months ago #126898 by 810
14 years 4 months ago #126934 by Matias
Do your users get 500 error when uploading attachment?
Jelle already put the original topic, but see also this:
www.kunena.org/forum/K-2-0-Support/12350...-known-issues#126931
We are going to release 2.0.1 within a few days to fix this and some other issues. Please report those! :)
14 years 4 months ago - 14 years 4 months ago #126936 by 810
Yes, i getting a error 500. when add a picture
Last edit: 14 years 4 months ago by 810.
14 years 4 months ago #126937 by Matias
Added issue from your another problem: github.com/Kunena/Kunena-2.0/issues/899
Time to create page: 0.147 seconds
