Question Is 2.0 Blue Eagle Mobile Friendly?
To broaden this discussion in order to speculate about the future Mirage template (which does not exist in K 2.0) goes against my better judgement but I offer the following observations that may or may not give you strategic information to assist you in your indecision to go with Kunena on your website.
(1) Blue Eagle is a table-driven template (based primarily on good ol' CSS2); Mirage is a tabless template that incorporates more advanced CSS features.
(2) It had been hoped that K 2.0 would incorporate two free, supported templates - Blue Eagle and Mirage - however there were significant problems achieving reliability with Mirage and it was decided to drop it from K 2.0.
(3) Development of the Mirage template continues; Mirage will be added in K 2.1 which is approximately scheduled to occur within the next 1-2 months
(4) I, personally, have not tested the Mirage for K 2.0 on a mobile device and so I cannot tell you how well it works.
(5) I do sympathise with you that mobile accessibility is important.
- jenifferjones
Alder wrote: Have you looked at www.mobilemews.com , I have just installed their Kunena template, and this works on a mobile, and on a desktop I use Blue Eagle, works with no fuss, just need to install their mobile template, all easy to do, works a treat for me.
Are you suggesting that your site is using BOTH templates for the same forum? And if so, how is this done please?
For the info.
I now have mobile phone templates working on all my sites.
when is Kunena 2.1 out OR more importantly the mirage template as you stated 1-2 months and that was 4 months ago? Any update?
