Question bug: same thread id at all edit buttons under a topic
17 years 8 months ago - 17 years 8 months ago #9067 by guerilla
hi, i am using kunena 1.0.8.
in message page although i push edit button of any other message except first message, the first message's edit page opened. when i get mouse pointer over the edit buttons all of them have same id with topics fist message. it is same with delete buttons. but quote and reply buttons seems normal.
note: i am using artio joomsef, is this problem's source this component?
Last edit: 17 years 8 months ago by guerilla.
17 years 8 months ago #9068 by grumblemarc
More than likely it is. Have you tried disabling it? Or at the very least make it bypass Kunena somehow?
17 years 8 months ago - 17 years 8 months ago #9089 by guerilla
i disabled artio joomsef and the ids are correct now. iknow this is not artio joomsef's offical site but have you got any idea about what can cause this problem?
thanks anyway...
edit:
i guess this is about getting id from address bar. cos i checked delete buttons and edit buttons' original links and they have for exmaple "id=162" string, but quote and reply buttons get id from "replyto=162" string. so joomsef accepts the topics first message's "id=162" string to all messages id. but i dont know the solution.
17 years 8 months ago #9109 by Lintzy
Perhaps, this could help:
There exists a plugin artio joomsef <-> kunena, but i guess, it works with kunena 1.07b, but i don't know really - give it a try. I must be installed over the artio install routine:
www.kunena.com/index.php?option=com_kune...view&catid=9&id=1554
17 years 8 months ago #9122 by guerilla
it works, thank u very much lintzy.
by the way i was using kunena joomsef plugin which i downloaded artio's offical website. i notified them about this bug, i hope they corrected this bug in new version.
17 years 8 months ago #9130 by vcardillo
Just as an aside, I disable all SEF relating to Community Builder and Kunena. Those components work SO much better without being wrapped in SEF. There's simply no need for it most of the time.
