- Thank you received: 1
Question Template not changing
I have downloaded Kunena today after stumbling across it. I have just installed locally and so far I am pretty impressed, but I am having a problem.
When trying to change the template from Kunena Configuration, nothing changes at the front end. I have refreshed, logged out and back in, tried each of the templates, etc. and nothing is changing.
Any ideas what the problem is? Should I try a quick reinstall?
Also, there are some nice little features that you have here that I can't seem to implement, such as collapsible categories. How do I go about adding that?
Cheers,
PLEASE PLEASE PLEASE keep up the great work.
- grumblemarc
- Elite Member
- Still making trouble
- Thank you received: 3
You should change both Template and Image sets to your new theme. Do you see any change in your backend?
Works for me.. If you cannot get it working, there may be some missing files. So try to install the component again (by using url, not download).
What changes should I expect to see in the backend? It is saving the setting if that is what you mean.
I will uninstall and try to reinstall from URL.
On a side note, is there anywhere that we can view a demo and select the different templates?
Hmm.. This may relate to some bug in 1.0.7b, but I'm not sure.
There are no 3rd party native templates for Kunena so it may be hard to make a demo.
